Power Commander module
I bought mine from www.mandmcycles.com. Mine is the PCIII usb. The Power Commander is made my the folks at Dynojet. It is a programmable ignition and fuel management system for fuel injected motorcycles.
It's not a Harley thing, and I don't think they will even install one. Check with them for sure, but I think they want you to purchase their ECM downloads.
Good luck.
[IMG]local://upfiles/494/3B5E2C4A6B134644B94557A074510791.jpg[/IMG]
Good luck.
Most Harley Dealers will install these (if they are a good dealer). You should have your bike dyno tuned at the time of installation if you want it to run right. I would not buy one from a dealer. Like mentioned above..you can save alot of money buying from someone else.
Terry
Terry
Yes you can self tune. If you have a laptop you can pull the program and make your adjustments and then reload the new program and even save the old program in case you make a mistake. You can save every little change you make by just renaming each program until you get what you want. They also have a manual way of changing things with buttons on the top of the PCIII.
If I was having an HD Dealer do the instal then I would buy directly from them just in case there are any problems. We all know with electronics **** can happen. Some dealers won't deal with parts not bought thru them because how do they know you didn't give them a defective part already and try and pin it off on them.
Just a little to think about
brad594
Jul 1, 2010 10:43 PM
