turn signal bulbs
Old Jul 25, 2017 | 07:31 PM
alexcalvin's Avatar
alexcalvin
Stage I
Default turn signal bulbs
i have 2015 flhxs what number signal bulbs do i need in front
Old Jul 25, 2017 | 11:22 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Try looking in your OWNERS MANUAL.
Old Jul 26, 2017 | 04:19 AM
rgrecco's Avatar
rgrecco
Im calling TROLL ALERT!
Old Jul 26, 2017 | 06:52 AM
Campy Roadie's Avatar
Campy Roadie
OP
Everything you want to know is here:
https://www.hdforums.com/forum/touri...ml#post8565003
Old Jul 27, 2017 | 10:44 AM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
Always 1157 Bulb Base in the Front since 1973. 1156 in the Rear, until they removed the center taillight and use the 2 Deuce Signals as Run, Brake & Turn, they use 1157. Run on the low filament and brake & turn on the high filament. Go with some Radiantz LEDs that retro fit into the stock housings. Since 2014, you should not need a Load Eq ( most of the time ).... https://www.radiantz.com/SearchResults.asp?mfg=Retrofit
__________________
LONG RIDE SHIELDS
www.longrideshields.com
fatbob
Jan 15, 2021 11:46 AM
riiano
Jan 10, 2013 08:26 PM
W1ldC4t
Nov 27, 2012 05:08 PM
gilyoyo
Nov 1, 2010 03:07 AM
larazauk
Sep 19, 2007 06:56 AM
