Hip soreness
Old Jul 27, 2017 | 08:25 AM
greygoosestr8's Avatar
greygoosestr8
1st Gear
Default Hip soreness
I've had my new-to-me 2010 Electra Glide Ultra Classic for about 3 months, put on about 1200 miles or so. I'm getting a soreness in my left hip joint from lifting my left foot to downshift. I know it's because I'm in kind of a seated/crouched position and to lift my foot causes strain on that tendon. My toe fits under the shifter comfortably. Do I need to lower the front shift lever or get a seat that sits back farther? Both?
Old Jul 27, 2017 | 09:06 AM
1HD1C's Avatar
1HD1C
my ankle doesn't move the way a heel shifter needs it to
so the first day I had the bike home I removed the heel shift lever
and covered the spline..
no more problems
Old Jul 27, 2017 | 09:10 AM
NELS's Avatar
NELS
Same problem as post one and same solution as post two
Old Jul 27, 2017 | 11:21 AM
grbrown's Avatar
grbrown
I only use the toe shifter - the heel shifter stops my foot from sliding off the foot-board! My heel is always on the footboard, with every gear change.
Where is your hip relative to your knee? If you are sitting with your knee higher than your hip then you may be putting too much strain on your hips anyway.
Deluxe Fatboy
May 14, 2016 12:04 PM
Rickr01
May 12, 2015 08:53 AM
hd74inca
14
Feb 17, 2010 06:19 PM
ripto
Sep 18, 2008 06:45 PM
Hardly Dangerous
Jun 7, 2006 12:10 AM
