No throttle past half open
Old Aug 11, 2017 | 11:42 AM
EdsRoadGlide2017's Avatar
EdsRoadGlide2017
Originally Posted by Jd1a
Now dead, will not run, still no codes.
My throttle was tight for a couple of weeks on my 2010 Street Glide. So much so that after a 300 mile ride my arm and shoulder were killing me and numb.
One day after cruising down the highway I got off at my exit. I was sitting in traffic. The RPMs went higher than usual. I twisted the throttle to try and loosen whatever was stuck. The throttle was dead. I had codes for the same. Its getting repaired as we speak. TBW.
Old Aug 11, 2017 | 11:10 PM
kojak's Avatar
kojak
2011 Electra glide, part throttle works, past half open is all noise. Just hear air sucking in the air cleaner. No open throttle acceleration. Any ideas? Will be checking codes tomorrow.
First try the easy fix, Turn the ignition switch on and off 4 times, pause for a few seconds in each position and don't touch the throttle. This should reset the TBW sensor.
If that doesn't work, your bike was going into limp mode and now wont run because of multiple possible issues, surprised that you don't have codes. Could be a bad induction module or frayed wires somewhere or you just might to clean the TBW plug. Right behind the air cleaner cover to the rear of the intake you will see a plug, that plug goes to the TCA (Throttle Control Actuator) disconnect the plug and clean it with some electrical contact cleaner then let it dry which should not take long, then get some good dielectric grease and put the grease on the plug ( it is hard to get the grease down in the plug so cover the plug as good as you can) do this to both the male and female part of this connection.
Old Aug 14, 2017 | 05:37 PM
Jd1a's Avatar
Jd1a
Drained the tank except for 1 gallon. Have a stream of fuel shooting across the fuel inlet, don't think that belongs there.
Old Aug 14, 2017 | 06:50 PM
dgoodbmw's Avatar
dgoodbmw
Default no throttle
sounds like it might be a cracked fuel filter or line inside tank. I bet it would run better when full of gas.
Old Aug 14, 2017 | 07:19 PM
Boomer1143's Avatar
Boomer1143
Fix that fuel leak and you should be good to go.
Old Aug 15, 2017 | 06:25 PM
Jd1a's Avatar
Jd1a
Had a full tank. have 16 psi on the pump and will not hold.
Old Aug 15, 2017 | 06:45 PM
dgoodbmw's Avatar
dgoodbmw
Default throttle
Think about it, if the pump wont hold pressure then somewhere there is a leak in the tank or the pump is bleeding off.
Old Aug 19, 2017 | 06:50 PM
Jd1a's Avatar
Jd1a
The fuel filter housing broke where the retainer clip passes through. One tab broke, will not hold pressure. It runs.
Old Aug 19, 2017 | 06:55 PM
dgoodbmw's Avatar
dgoodbmw
Default fuel filter
I was pretty sure. Glad you found it.
Old Aug 19, 2017 | 10:20 PM
leon anthony's Avatar
leon anthony
my brother and myself were coming home to the San Francisco bay area we were on Highway 70 heading west out of Denver when his 2007 ultra started to miss we got down to about 20 m p h then he could sometimes coax it backup to aroumd 40 we made in into Glenwood Springs to Doc Holliday Harley on Friday afternoon and they had it running bu noon Saturday It was the same problem as Jdia hda
