Spark issues
Old Aug 6, 2017 | 10:52 AM
Tmore's Avatar
Tmore
Stage IV
Default Spark issues
2004 Electra Glide/police fuel injected
Got a bit of a problem and some help. A few days ago, I hopped on the bike and hauled *** down to Charleston from Vermont, about 1200 miles. Bike ran like a beast all the way down, quite proud of it. However, after it was parked for 10 hours, it wouldn't start. We believe the problem to be lack of spark. Here's what I know:
-Run switch will engage the fuel pump to prime the engine
-Battery is fully charged, put it on a charger to top it off just in case.
-Fuses all look good
-Wiring harness to ignition coil doesn't appear to be damaged, neither do plug wires
-Ignition coil is brand new, replaced when spark was determined to be issue
-Plugs are brand new and gapped
-Plugs will not fire, checked them against the engine to ground, neither sparks
At this point, I'm down to either I missed a fuse, a bad ground, or the icm has gone bad. But I also just saw something about a crank sensor as a possible culprit. I've gotta get this bike up and running by the end of the week to make the trip back, so I'm wondering if anyone has any ideas on what it could be. Fixing it isn't the issue, it's just finding out what's wrong in the first place and electric was always a weak point for me
​​​​​​​Thanks
Old Aug 6, 2017 | 11:14 AM
FastHoss's Avatar
FastHoss
Any engine codes?
Old Aug 6, 2017 | 01:59 PM
Tmore's Avatar
Tmore
Stage IV
No reader to check. The check engine light never came on while riding it down. No doubt it's gotta be spitting a code at me now, though.
Old Aug 6, 2017 | 02:24 PM
FastHoss's Avatar
FastHoss
Search this forum for how to retrieve codes. I don't remember how.
Old Aug 6, 2017 | 02:47 PM
Tmore's Avatar
Tmore
Stage IV
Oh, by the fickle automotive gods, I love the engineer that thought to give it a diagnostic mode.
​​​​​​​it's giving me three codes, 2 of which are most likely related to me dickering around with it, which are front ignition coil open/rear ignition coil open. The last is "CKP sensor not detected". I'll have to double check, but if that's not present, there will be no spark whatsoever.
Old Aug 6, 2017 | 04:54 PM
Tmore's Avatar
Tmore
Stage IV
So, 64 bucks and an hour and a half later, I have a new sensor and a running bike. Thanks hoss for letting me know that I could retrieve codes on the bike, turns out I just made it for having that diagnostic tool, they started in 04.
Old Aug 6, 2017 | 08:43 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I remember driving around town in a Pickup with known stumbling or no starts, we ran a tattle tale on the OBD and that lead us to a crank position sensor also. Glad you got back on the road fairly quickly and hopefully you enjoyed your ride home.
Chango1079
Aug 16, 2019 11:37 PM
lynmark1
EVO
22
Jan 30, 2015 12:44 AM
Rider98Glide
Sep 8, 2011 07:11 PM
pizablo187
Electrical/Lighting/Alarm
Jul 31, 2009 07:50 AM
Dworrakk
Apr 4, 2006 12:07 AM
