I have a similar problem with the cable running from my sandisk music player to my radio input. I've replaced that thing 4 or 5 times. Sometimes the cable will last a year and other times only a few hundred miles. I wish I knew what was causing them to go bad so quickly.
I've got my phone (Samsung S7 Edge) mounted on the Klock Werks magnetic mount.
I think touring wrecks USB cables.
Ran one a few days, then charging got wonky.
Replaced cable, fine for a few days, then wonky again. Last one was a not-cheap Anker cloth wrapped one.
The cable is hanging straight down, no weird angles, but I'm thinking vibration wears them out?
Anyone else have this problem?
Might be a thing. My microUSB plug for power to my S6 mounted on my fairing is starting to get 'loose'. Only been running it like 3500 miles. I was thinking vibrations are the problem - but microUSB have those little spring tabs, so it sort of makes sense to me. You have USB-C on your S7, don't you?
Been using the same micro usb cable on my bike to phone for about 5 years, never a problem. 2 amp source, phone on a RAM X Mount.
USB C started with the Note 7, best phone I ever had up until they killed it. I am also with the 6 Edge, waterproof is a big plus.
I also use a Deltran connected 2 amp supply to another micro usb for the passenger, no issue there either.
