Odd engine light issue
Old Aug 16, 2017 | 03:07 PM
oldsoldier181's Avatar
oldsoldier181
Default Odd engine light issue
So, I own a 2002 RKC with about 33k miles on it. Bought used. Have had it for about a year, I have put 6k miles on it so far. The previous owner had it all serviced at the local dealer, so I have all the maintenance records. There are no upgrades on it, its still an 88. That all being said, I had an odd thing happen yesterday, and was just wondering if anyone else ever experienced this.
So, yesterday, I start my bike up. Goes through the normal prestart lights, no issues.
Starts up fine, no issues.
After about 5 seconds, the engine light illuminates. After 10 seconds, it then goes off, and stays off. I rode it last night and today, to double check, but it never comes back on during operation.
It does do that weird cycle every time though. No matter if its warm, or cold. It illuminates shortly after starting up, stays on for 10 seconds, then goes off.
I checked the oil, that looked fine.
Any other suggestions? I dont think it is throwing an actual code, so I havent checked that yet. I just wanted to see if anyone else has had that problem and what, if they did, the solution was.
Old Aug 16, 2017 | 06:21 PM
dawg's Avatar
dawg
Sounds like a code to me. I'd check for historical codes and clear them/correct the issue that caused the code, etc.
Old Aug 16, 2017 | 06:43 PM
oldsoldier181
Do I need a code reader? Or is there a button sequence I can access it with?
Old Aug 16, 2017 | 06:56 PM
dawg's Avatar
dawg
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector. Other models will be under the seat.
2. To activate the diagnostic feature,follow these steps.
a. Create diagnostic test wire or use a female spade clip which will bridge the two terminals perfectly.
b. Install diagnostic test wire/clip across Terminals 1 and 2 on the data link connector, they are marked.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A “trip” consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period).
The first number is the ranking number. The numbers after the 'historic' or 'current' is the speedo CEL (check engine lamp) code number (lamp flash count), but without the electrical diagnostics manual you're not going to know what they mean.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)
10 Current 24 Loss of vehicle speed
10 Current 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Old Aug 16, 2017 | 07:14 PM
Tarkus60's Avatar
Tarkus60
Yea what he said.....^^^^^
There is a electrical trouble shooting manual,
I fixed my cruise control with it......
Old Jul 31, 2020 | 04:47 PM
Gerson Moura's Avatar
Gerson Moura
Stage I
Guys, I need help.
I have a Night Train 2000 that has been experiencing problems with unoperated engine shutdown. I checked the error codes that the ECM has on the speedometer, I got three errors: 12 MAP sensor open / low, 12 MAP sensor high, 41 CKP sensor intermittent, 41 CKP sensor synch error, 41 Ignition switch open / low, and an error 44 that is not in the error table. Does anyone have experience in the exact interpretation of these errors? Any help will be very helpful.
Old Aug 2, 2020 | 09:33 PM
Mr. Mike's Avatar
Mr. Mike
Gerson,
Welcome to the site.
Your bike being a 2000 year model, I’d check each related connections for corrosion and plug integrity. You can remove and wipe off the crank position sensor to see if that changes (metallic debris on the sensor can cause errors)), but the MAP sensor....just replace it.
Same for the Crank PS, replace it if there’s no change after cleaning.
The other errors for ignition switch and the weird 44 error may just go away when the others are sensors are renewed. You’ll be the first to know.
*NOTE* Start yourself a new thread specific to your trouble for better response. Good luck.
Old Aug 2, 2020 | 09:44 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Crank position sensor and MAP sensor....
I can see if it does not know where the crank is why it can't tell the coils when to create spark
That is the old MM FI system in that bike, if it is good luck.... you are going to need it.
20 year old system that HD stopped supporting years ago, my HD Guru would be ripping the FI out and putting a carb on it, I know he has said there is a rework of the ignition system of some sort required, but he made it seem that it is the easiest way around a MM FI issue.
Check the wires, check the connectors, go from there
Chief_Confusion
Nov 4, 2018 01:58 PM
swartybyrd
Sep 18, 2018 10:00 AM
bubbadiaz
Oct 9, 2011 05:17 PM
wideopen1967
Sep 26, 2011 01:00 PM
ptmyers01
Jul 8, 2010 09:53 AM
