Replacement speedo
Old Aug 27, 2017 | 11:20 AM
Open Road King's Avatar
Open Road King
6th Gear
Default Replacement speedo
Replaced with the harley combo tach/speedo part #70900072A. It works properly, only thing I can twist it slightly to the right. It doesn't move when riding just a bit annoying. Perhaps the gasket didn't get seated properly? Any ideas?
Old Aug 28, 2017 | 01:18 AM
Mr. Mike's Avatar
Mr. Mike
Only ideas I can come up with are;
1) You reviewed removal and installation procedures as outlined in your service manual (in conjunction with the kit instructions)?
2) Thinking back, you're certain you tightened all fasteners?
3) Any original gaskets to be re-used that maybe got overlooked at reassembly?
Might be worth disassembly to check, as it may not be water tight if it is supposed to be by design.
Sorry if these sound juvenile, and certainly not meant to offend, but it's easy to make mistakes on the simplest of repairs/mods, and like most, I hate going backwards.
Old Aug 28, 2017 | 01:28 PM
dyna rider's Avatar
dyna rider
Default Speedometer Replacement
Did you do the work yourself or did your local dealer do it ? The reason I ask is there is usually a bracket that bolts to the bottom of the speedo and holds it to the housing and that may be loose.
HD speedometers are NOT water tight. Early this spring, I replaced my Dyna speedo that I had been bitching to the dealer about since I bought the bike new. It would always fog up after a rain storm or after a bath. I never used a high pressure washer on it, only a water hose.
Old Aug 28, 2017 | 01:33 PM
todd-67's Avatar
todd-67
I have that same unit in my king and it doesn't move.
scooby636
Oct 13, 2021 09:41 AM
Wide Glide 25
Apr 12, 2013 01:48 PM
diablo666
Jul 3, 2011 10:10 AM
ChopinRockwooD
Apr 25, 2009 08:08 AM
jlsk624
Jul 9, 2006 09:41 PM
