Brakes?
Old Jun 12, 2007 | 12:41 PM
Harley Rulz's Avatar
Harley Rulz
Default Brakes?
I'm trying to get ready for My 12 day Colorado trip and was just wondering if anyone knows the average life of the brakes on the Electra Glide.The bike is not where I can check it out for a few days (don't ask [&o]) or I'd take a look see.I know this is a loaded question but I just thought there might be an educated guess from You guys.
Old Jun 12, 2007 | 12:44 PM
Hdbiker1450's Avatar
Hdbiker1450
Default RE: Brakes?
Don't think there is a real average. All depends on your riding style. Simple job to replace em though. I'd be sure to check it out and then DIY before you go if you need em.
Old Jun 12, 2007 | 12:50 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: Brakes?
When in doubt, replace 'em - cheaper than hearin' grindin' metal on a trip! Thar's so many variables involved ah doubt anyone could give ya an accurate range....
Old Jun 12, 2007 | 01:32 PM
Harley Rulz
Default RE: Brakes?
I kinda knew it was a dumb question but oh well.Thanks for the feed back fellers!I'm gonna change them.
Old Jun 12, 2007 | 03:49 PM
Kahuna's Avatar
Kahuna
Default RE: Brakes?
Harley,
Your question was not a dumb one. The wear on the pads are based on several factors: your riding and braking style, what pads you're currently using, and how often you clean your caliper pistons.
I, personally, don't like HD stock pads. Most on this site use the Lyndall Racing Pads or something comparible. Your braking style will also determine your pad wear. Do you use more front brakes or rear brakes when braking? I tend to use about 70% front and 30% rear. This helps both front and rear pads wear more evenly together.
Also, your pads will wear more evenly if you disassemble your calipers and clean the pistons every 3,000 miles or so. This will also help firm up your front brake lever as well.
Hope this helps!
Kahuna
ORIGINAL: Harley Rulz
anubisss
Aug 8, 2007 08:43 PM
