My luck ran out
Old Sep 13, 2017 | 09:41 AM
roaddog's Avatar
roaddog
Originally Posted by btsom
"Gummed up inside", was that the electric motor part or the pump part? If brushes, bearings, or failed seals are making the motor fail, a new pump may well repeat the process. If coolant is gelling in the pump, that is a different problem. Either way the MOCO needs to know what is going on. The proper cure depends on an accurate description of the problem. Makes me wonder if the "fix" will be a total COOLANT flush every two years. Harley makes no mistakes, it is you owners failing to do proper, timely maintenance that cause all the problems. Wonder how Harley would handle a class action suit.
Pump Gummed Up
Old Sep 13, 2017 | 10:23 AM
hardheaded's Avatar
hardheaded
what the hell would make the pump "gum up " on a fairly new bike ? cars go 100,000 miles on the same coolant.
Old Sep 13, 2017 | 12:32 PM
risuperglidecustomman's Avatar
Very Interesting keep us informed
Old Sep 13, 2017 | 12:38 PM
saltlick's Avatar
saltlick
man, is there an indy bike mechanic around since your out of warranty? Id skip going to the dealership unless you want to pay big $$$ for crappy work.
Old Sep 13, 2017 | 12:51 PM
CSS899's Avatar
CSS899
Just got home from a 14 day trip in Colorado. Same thing happened to my friend on his 2015 limited ( bike had 18K on it) in Durango. Dealer there was great and took him right in. Turns out it was the water pump. Pump was $400 plus labor. His was covered under ESP. He was told he could ride it in without damaging anything but we trailered it to be safe. Good luck.
Old Sep 13, 2017 | 02:55 PM
ROCKOUT Rocker Products
Sponsor
On mine it was the pump part. There is no direct drive from the motor to the pump.... it's "magnetically coupled"... a drum with magnets in it spins around a magnetic core. Doesn't take much resistance to make it stall.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
GeneseeGap
2014-2024 Touring Models
45
Sep 2, 2024 08:15 AM
clackavosticus
Nov 16, 2017 12:58 PM
FinalShot
Sep 2, 2017 09:44 AM
Grmullins62
43
Aug 13, 2017 10:11 PM
tom071200c
Jun 7, 2009 12:25 PM
