Front wheel Bearings
Old Oct 29, 2017 | 04:59 AM
svarnster's Avatar
svarnster
I don't know the numbers, but if u get the number on the side of the bearing the bearing supply place can cross reference it to other brands. I have done this many times.
Old Oct 29, 2017 | 06:06 AM
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by Cosmic Razorback
Radial ball bearings are not designed to axial and thrust loads.
Too bad they don't use Timken tapered roller bearings. Of course it is a $$$$$$ and cents thing.
Many bike brands have been using ball races for their wheels for decades without problems, although there is no denying that tapered roller bearings are superior. My 1990 Evo, owned from new, has never needed new tapered bearings. There may be a unit cost penalty in using them, however the major issue is labour - they cannot be installed without first being assembled, checked and reassembled after shimming. I suspect that is the main driver in H-D going to *****.
Old Oct 29, 2017 | 01:47 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Originally Posted by memphisharley
I know a bearing supply place locally. again, does anyone know if the hd abs bearings are proprietary .
Personally, I do not know of anyone else that makes the ABS bearing.
Old Oct 29, 2017 | 02:01 PM
L88's Avatar
L88
Originally Posted by Greg2012FLHTK
Mine would start making a noise that sounded like a jet engine around 20 mph.
Yep, got that now on my RK at 1100 miles. It set outside quite a bit before I bought it and probably got power washed a few times.
Not hard to do with a Pit Posse VT102. Just time and a little creativity to do the rear wheel pulley.
Old Oct 29, 2017 | 02:02 PM
L88's Avatar
L88
All ***** makes an ABS kit for both Front and rear.
Old Oct 29, 2017 | 02:14 PM
lt1-xjs's Avatar
lt1-xjs
Here's another, http://www.dragspecialties.com/produ...umber=02150964
Old Oct 29, 2017 | 03:13 PM
memphisharley's Avatar
memphisharley
thanks..i have used them before for bearings for my k6. i will check them out as well as a good local supplier. I have a used abs bearing I can present to the local so I'll see what they say.
drag specialities may be a good bet also. thanks.
Old Oct 29, 2017 | 03:36 PM
Boomer1143's Avatar
Boomer1143
I've been running a set of these on my bike for the last 17K miles. Non ABS and ABS bearing in kit form.
https://www.ebay.com/itm/Drag-Specia...RZGLDz&vxp=mtr
Old Oct 29, 2017 | 05:09 PM
Spartanden's Avatar
Spartanden
I lost the right front bearing this fall on our annual trip....31k miles. On the highway. In the middle of nowhere. So I thought... Shanendoah Harley was just a couple miles away, and took care of me!! Felt like I was driving over rumble strips, front end vibrated off and on, and front brake felt strange. Definitely one thing that gets checked at each tire replacement!!!
Old Oct 29, 2017 | 05:16 PM
Tired's Avatar
Tired
Use any brand bearing you would like with this encoder kit.
