Tiny Spring - What is it?
Old Oct 28, 2017 | 09:59 PM
Uncle Larry's Avatar
Uncle Larry
It controls oscillation from the apparatus that re-calcimines the fortiscube ... in the floorboard, of course :>)
Old Oct 28, 2017 | 10:30 PM
Mr. Mike's Avatar
Mr. Mike
What he said or your lift is missing one of four springs. Better check.
Old Oct 28, 2017 | 10:32 PM
6 gun's Avatar
6 gun
check your passenger foot boards there is a spring in there under a ball or something.
Old Oct 28, 2017 | 11:51 PM
AtticusFinch's Avatar
AtticusFinch
We did try that. That was the best the guy at Legends could come up with too. He had a repair kit for the floorboard and we were able to compare the two springs. The floorboard spring is actually quite a bit larger than this spring. Thank you (and everyone else who suggested this) for giving it a shot though.
I think that one of the tools I was using is the most likely culprit at this point. I’ll go through them and see if one seems to be missing something.
Old Oct 29, 2017 | 01:52 AM
Bone Doc's Avatar
Bone Doc
Did you remove/replace your switch caps? More specifically, the high/low beam switch. It is a mechanical switch that uses very small copper terminals with springs over them to hold the switch in the low beam or high beam position. It's a crappy design.
If the spring is from that switch, the switch won't "lock" into position.
Old Oct 29, 2017 | 06:27 AM
voodoodrug's Avatar
voodoodrug
althoough parts manual is online, I have found im regularly thumbing through the pages to identify the parts that might have fallen off.
Old Oct 29, 2017 | 06:33 AM
bpav16's Avatar
bpav16
I looks like the spring in the passanger floorboard
Old Oct 29, 2017 | 07:15 AM
Bone Doc's Avatar
Bone Doc
That was the general consensus but the OP indicated...
Old Oct 29, 2017 | 07:22 AM
Cobra1's Avatar
Cobra1
Have you replaced the brake light switch in the right handlebar control module? Looks like the spring from that switch.
Old Oct 29, 2017 | 10:33 AM
Boomer1143's Avatar
Boomer1143
Have you been working on your AR-15 lately? It looks like a disconnector spring to me.
Amazon Amazon
