SERT Question
Old Jun 14, 2007 | 11:49 PM
ddwyer's Avatar
ddwyer
Default SERT Question
I'm doing research on changing out my pipes and air cleaner, and am leaning towards the SERT over the PC III based on all of the comments I've read. What I have been unable to find is the latest SERT manual which covers the 07's and what canned/pre-tuned files come with the SERT?
I'm looking at getting Rinehart True Duals, with the SE Air Cleaner for my Road King Classic. I'm assuming there is a canned map that will cover this configuration, but want to be sure before I spend the cash. While I know a dyno tune is the way to get the best performance, I just want to ensure I can drive it around until I have a moment to drop it off for a dyno.
Thanks for any input.
Old Jun 15, 2007 | 12:36 AM
Wags1's Avatar
Wags1
Default RE: SERT Question
The cals that are included cover '07's but are tuned for SE stuff only. So, you won't find anything specific to Rinehart true duals but you will find a cal for touring bikes, stock engine, SE Air Cleaner and "racing" pipes that will be close enough.
I have the SE AC and Rinehart SO's on the stock headers on my '07 RKC and the canned cal was pretty close. I have since made some modest tweaks on my own but have yet had it in for a dyno tune. Plan on doing a data run or two this week end and tuning a bit myself.
Old Jun 15, 2007 | 01:57 AM
gman's Avatar
gman
yup, i agree. select a map that is close to what you have. then check the plugs for a lean condition. have heard some have used the 103 ci map to richen it up. i elected to dyno and have a custom map built for my UC using my SERT, but a good start is just using a map that is close to what you have and tweaking from there.
Old Jun 15, 2007 | 07:59 AM
ddwyer's Avatar
ddwyer
Thanks for the advice. I plan on doing the install myself, and just want to make sure I can have something to ride around with prior to getting the dyno tune. It sounds like SERT offers the most flexibility for tuning.
Old Jun 15, 2007 | 05:12 PM
Biggzed's Avatar
Biggzed
ORIGINAL: ddwyer
Not sure what year your bike is, but have you looked at hdmaps.com? They have lots of Rhiehart maps for sale.
Old Jun 15, 2007 | 05:30 PM
UltraKla$$ic's Avatar
UltraKla$$ic
ORIGINAL: ddwyer
You'll use Calibration #67 File Name 159AE003-A1.MT6 which is indicated for the Shotgun/Shorty Dual Exhaust setups for the '07's.
HERE and HERE offer some light reading and explanation if you are interested.
Old Jun 15, 2007 | 05:40 PM
Wags1's Avatar
Wags1
I am curious what the real difference is between calibration # 67 and # 78. It is really not clear in the write ups that are in the PDF file. They do not have a clear description of what they mean by "Shotgun/Shorty Dual Exhaust" vs "Touring Exhaust". Here are the PDF descriptions -
Calibration # 67: 2007 Shotgun / Shorty Dual Exhaust with O2 Sensors
Configuration: 1580 SE A/C & Race Exhaust
File Name: 159AE003-A1.MT6
Components:
• 25deg Injectors P/N 27709-06
• SE Air Cleaner and Breather Kit P/N 29440-99C
• Race Exhaust
Calibration # 78: 2007 Touring Exhaust with O2 Sensors
File Name: 159PZ004-A1.MT6
Components:
• Race Exhaust
Old Jun 15, 2007 | 05:46 PM
UltraKla$$ic
Touring exhaust's refer to the stock headers which closely mimick a 2:1 pipe. True duals are free(er) flowing pipesin which the VE tables are setup more closelyandfunction better with the Cal #67 Shotgun/Shorty map.
Read the second thread I listed and ShovelHeadBob re-enforces this.
Old Jun 15, 2007 | 05:56 PM
Wags1's Avatar
Wags1
Excellent, thank you that does clear it up. I suspected this but it is certainly not clear from the way they have it written up in the calibration descriptions.
I do find it interesting that by in large the documentation, both the user manual and the pull down help in the software itself, for the SERT is really very complete, clear and concise, with the notable exception of the documentation on the calibrations wrt the different exhaust configurations.
Old Jun 15, 2007 | 06:04 PM
Todd T's Avatar
Todd T
Another difference from the 67 and 78 tune are the closed loop bias tabels are alot larger on the 67 map.
I chose to run that map in mine after going to the true duals, I tweaked the idle lower just a bit too.
