Etms
Old Nov 7, 2017 | 08:25 PM
skratch's Avatar
skratch
Originally Posted by nobodyknowsme
I haven't checked mine since first being set and really don't pay attention. But are you saying that rolling the throttle forward will automatically shut it off? I hope not as that is one of the ways I disengage cruise control.
yes, that is how you engage/disengage it. but not to worry, it takes more time than just the quick roll forward that you would do to disengage cruise.
Old Nov 7, 2017 | 08:28 PM
nobodyknowsme's Avatar
nobodyknowsme
Thanks brother, will check it out tomorrow.
Old Nov 8, 2017 | 08:55 AM
btsom's Avatar
btsom
I believe the OP claims he gets the one lung idle even before the machine is up to temperature. If my understanding is correct, he has a problem separate from just accidentally rolling the throttle forward. EITMS should NOT activate on a cool engine. If this continues, you have a warranty problem to be looked into at the dealer.
Old Nov 8, 2017 | 10:10 AM
Crimson's Avatar
Crimson
I thought the new bikes engage it based on outside temp and not engine temp? My 2013 does it based on engine temp but I thought that changed with 2014+ bikes.
Old Nov 8, 2017 | 01:46 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Just a slight pull on the front brake lever or pressing the foot brake will also dis-engage cruise control.
Old Nov 8, 2017 | 03:37 PM
hardheaded's Avatar
hardheaded
14 and newer bikes it comes on when the outside air temps hit 80*
Old Nov 8, 2017 | 03:40 PM
MilesOfTexas's Avatar
MilesOfTexas
You should be ok to do that to disengage the cruise control without causing a change the the EITMS. You have to hold the throttle forward for a few seconds to cause it to engage or turn off. On my '14 Limited, I have to roll mine forward for a few seconds, release, then roll it forward and hold it for a few seconds again to turn it on or off.
Old Nov 8, 2017 | 05:32 PM
memphisharley's Avatar
memphisharley
how does one know if it has been accidentally shut off. are there any indicator lights.
thanks
Old Nov 8, 2017 | 09:20 PM
skratch's Avatar
skratch
when you engage/disengage it, the cruise control light will flash either amber or green.
Old Nov 8, 2017 | 09:26 PM
judgedelta's Avatar
judgedelta
Push your information button on the right control assembly and it will show if the EITM is on or off.
