Neutral Rattle?!
Old Nov 16, 2017 | 09:15 PM
DrPaul's Avatar
DrPaul
2nd Gear
Nobodyknowsme....you wouldn't happen to be in Phoenix would you? I'd be more than happy to take my business to an Indy with great, trustworthy mechanics.
Old Nov 16, 2017 | 10:51 PM
Artexman's Avatar
Artexman
My inner primary bearing just started making noise and I can hear the noise while in neutral or in gear going down the road but if I'm stopped and hold in on the clutch and put it in gear it does quite down considerably. I'm not saying this is your problem but it does sound similar. Good luck with your hunt and end results. Ride safe and God Bless...
Old Nov 17, 2017 | 03:52 AM
nobodyknowsme's Avatar
nobodyknowsme
Sorry brother, couple thousand miles away but I offer this. If you are relatively new to this check with some seasoned locals, bars if you have to. Find out from folks who they trust. When I have been traveling and need something maybe I have just gotten lucky but a good Indy, especially in a place like where you live should not be that hard to find. Best of luck and let us know how this goes. We all learn from each other.
Old Nov 17, 2017 | 06:49 AM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Neutral rattle can only be heard when in neutral. You do not hear it when in gear or with the clutch in
Old Nov 17, 2017 | 07:14 AM
RayK's Avatar
RayK
I agree, my bike was doing this. HD has a bulletin explaining the cause of the rattle. Rattles in neutral when hot, change oil to a heavier gear oil and it goes away.. I now use Amsoil trans oil.
Mike flies
Oct 3, 2017 03:22 PM
sporty06
Aug 14, 2007 02:51 PM
marcus84
Sep 6, 2006 12:19 PM
jmbear328
Aug 23, 2006 12:52 AM
sws1
May 14, 2006 01:21 PM
