Help with slip on too short for brackets
Old Nov 18, 2017 | 05:45 PM
criyi's Avatar
criyi
Default Help with slip on too short for brackets
so I talked with baddad and ordered a slip on pipe that they said would work. It fits my stock header pipe and the pipe is perfect length and looks and sounds awesome. The only problem is the rear muffler bracket is short. Im able to use 1 bolt which I could cut off but I’m afraid that wont be a good long term solution. With this setup its tight at the exhaust and stable at the rear but for how long? My thought was to get a longer length using both bolts that would overhang into the bracket. Any idea if they sell longer lengths that I could drill the holes? Any other thoughts or suggestions?
Old Nov 18, 2017 | 06:10 PM
Rdcris's Avatar
Rdcris
Had the same problem when I mounted a set of used V&H Monster Ovals.
I called V&H and explained the issue and they sent me the correct brackets.
Think I paid like $45.00 plus shipping.
I don't remember the part numbers but your situation looks just like what mine did.
One bolt will not work for long.
Give V&H a call.
Old Nov 18, 2017 | 06:17 PM
2015UltraLimited's Avatar
2015UltraLimited
Looks like you need the bracket similar to the ones for V&H Monster Ovals. Here is a pic.
Edit: Looks like RDCRIS beat me to it when I went to the garage to snap a pic. I agree with you.
Old Nov 18, 2017 | 06:49 PM
2015UltraLimited
I just unwrapped mine to take a photo to help reference with a measuring tape for your issue. P/N 507-p after you call V&H, if $30 shipped is good for you, you can have these. Never installed, not a scratch on them.
Q: What is the distance between the two fixed nuts on the slipon? 2”? If so, then the V&H brackets will work. They are closer than stock bracket. If you flip over your stock bracket in your photo and the holes line up, the Monster Oval brackets will not work for you unless you drill another hole.
Old Nov 18, 2017 | 09:26 PM
criyi's Avatar
criyi
Wow thanks guys, that looks like exactly what I need. $30 shipped, I’ll take it! Do you do paypal?
Old Nov 18, 2017 | 09:41 PM
TSheff's Avatar
TSheff
Well that was easy.
Old Nov 18, 2017 | 10:09 PM
2015UltraLimited
Pm sent to ensure fitment along with PayPal info.
Old Nov 19, 2017 | 12:22 PM
2015UltraLimited
Good luck with fabricating new brackets. To bad the V&H brackets were still a bit short as that would have been to easy.
Old Jan 1, 2020 | 10:02 PM
BackRoader's Avatar
BackRoader
Those are the right brackets, but you also need a flat bar thing with a nut on each end that slips under the mount on your mufflers. The black bar in pics sets on top of the muffler bracket and bolts go through the top holes and screw into the bolt bar thing.
Old Jan 1, 2020 | 10:03 PM
BackRoader's Avatar
BackRoader
well sheet, who resurrected this ol thread?
