Transmission problems
Old Dec 16, 2017 | 06:39 PM
kickstartfan's Avatar
kickstartfan
Deleted.
Please continue.
Old Dec 16, 2017 | 08:58 PM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by 2black1s
Check the compensator... The bolt or nut, not sure which the 2003 had, may have come loose.
I'd say this dude could be right ^
2003 was the first year for left side roller bearings, in lieu of Timken tapered. The comp nut bottoms out on the crank shoulder (it isn't supposed to) and needs .030 taken off off or a a spacer installed; there's a TSB on it. Get on this ASAP, if the comp gets too loose it'll **** up the splines on the crankshaft. That, is expensive.
Old Dec 17, 2017 | 01:36 PM
btsom's Avatar
btsom
The belt may look good, but how tight is it?
Old Dec 17, 2017 | 01:40 PM
flashprez's Avatar
flashprez
Check shifter linkage coming out of trans to make sure it is not stripped not allowing it to go in gear.
Old Dec 18, 2017 | 10:54 AM
grbrown's Avatar
grbrown
With all the different suggestions above, there is no substitute for consulting someone who can see and touch your bike. Find a local indy to properly diagnose the problem for ya and also fix it.
Old Jun 11, 2020 | 10:43 AM
SeanDoe209's Avatar
SeanDoe209
4th Gear
Originally Posted by 06BlackWG
When I put the transmission in any gear it sounds like the gears are sliding over the top of each other. The bike doesn't move. What should I look for? Getting ready to open it up.
I'd definitely start at the clutch pack.
1. After you pull your primary cover off you can squeeze the clutch lever in and out and observe your pressure plate to ensure that it's going in and out to engage /disengage the clutch pack.
2. When the pressure plate is engaged (pressure on the clutch pack) if you can get a finger on the edge of the very last friction plate well the pressure plate is engaged if you can wiggle it or has any type of play. The clutch won't engage at all and clutch pack is probably burnt out
3. Click the bike into third gear ( while the bike is on a Jack and the back tire can spin freely) with the primary cover off, hold the outside of your clutch basket with one hand and spend the back tire with the other. If the inner basket and outer basket/pressure plate spins freely from each other the problems in your clutch basket. If the back tire spins and the entire clutch basket dosent move. Then you may be looking at a stripped main belt drive sprocket or shaft. ( behind the primary housing is the sprocket and belt drive that goes from the transmission to the back tire)
I hope this helps ya
Old Jun 11, 2020 | 10:44 AM
SeanDoe209's Avatar
SeanDoe209
4th Gear
Old Jun 11, 2020 | 11:20 AM
Max Headflow's Avatar
Max Headflow
The chances are that the tranny pulley cam loose and splines stripped. It could be the spines on the clutch hub but on the 5 speed TCs it's not so common. IT's not likely the comp as if it were the bike would not start.
Old Jun 11, 2020 | 03:08 PM
predatornut's Avatar
predatornut
If he is still working on this he is slower than I am.
Old Jun 11, 2020 | 09:01 PM
Max Headflow
Hey I only looked at the date on the previous post..
sB43
EVO
Jun 18, 2018 04:13 PM
Oldsarge29
Oct 28, 2012 11:07 PM
1993mooglide
Jun 23, 2009 11:11 PM
Frog33
Mar 4, 2009 09:57 AM
wolf1477
Ironhead
Jan 16, 2007 04:23 AM
