I have a Snap-on TechWrench. 3/8" drive, around $300. Yeah, expensive. But it is electronic - vibrates and beeps when you hit the torque setting, which is set digitially. Oh, and you can choose in-lb, ft-lb, or Nm. And it'll read from 5 to 100 ft-lbs. You'd have to have two or three torque wrenches to get that kind of range. I've been using this thing for the last four years, and I would buy it again. There's one like it on ebay here. Looks like used they're going for about 150 or so.
I have noticed in the manual they sometimes refer to foot pounds and sometimes to inch pounds. I have a conversion chart that came with my torque wrench so all I do is look up the conversion.
Using a foot pound torque wrench to do inch pounds is not a good idea. Most of the time you will be below 10 ftlb. The chance of precision error is high.
Just divide your in. lbs. by 12 and thats your ft. lbs.. 120 inch lbs is 12 foot lbs.
You mean divide your foot lbs by 12 to get inch lbs. Or if you need to go the other way then it would be 120 inch lbs = 10 foot lbs. 12 inches in a foot. 12 goes into 120, 10 times.
