Considering a 103 cam swap
Old Jan 14, 2018 | 11:28 AM
  #51
KumaRide's Avatar
KumaRide
Originally Posted by Bafflingbs
Now, to your other points; the 57’s are good, but unless you add compression (which at least #2 did with a .030 head gasket) or do the +4° crank gear, the later intake closing of the 57’s (38°) pushes it more to a mid range cam. I’m also betting the stock headpipe was de-catted.
So, youre saying a decatted header performs better then a stock haeader. Tell us, what gains does a decatted header have over stock header? How much and where are they? Does a decatted header perform the same as a $500 header? And what is the ideal compression for 57s?
Despite what you "think" about stock or decatted header and 57's compression requirements, 57's with stock compression and without the $500 header performed sop same as 222's with a $500 header. And if you "read" the sheets, the 57s with stock header peak tq was at same rpms as 222. Does that make the 222 a midrange cam also?
To be clear, I dont care what cams, header, mufflers, others run. Most seem to like what they chose and thats how it should be.
Old Jan 14, 2018 | 07:10 PM
  #52
Bafflingbs's Avatar
Bafflingbs
I meant to say the CR570's were aided by a .030 gasket. (#2) I'll man up and say when I'm wrong. The stock headpipe would almost surely aid the low end loss for the 57's. The headpipe would add valuable back pressure for that cam. From what I'm gathering, 10.2/1 static pressure would be the most for the 57's. The latter opening and closing of the intake valve, of 18/38 do place it in more of the mid-range territory. With 35 being considered the cut off for low to mid. The 57's would be more of a performance cam. The 222's opening and closing is 14/34. At least that's what I've read here: https://www.hdforums.com/forum/engin...1-and-2-a.html
Even with my $500 header, the 222's break a hundred at 2500 rpm's. With more back pressure, they'd probably be closer to 2000 rpm's. Honestly, I don't know what I was thinking about the decatted header Also, if that's your dyno, you've got great numbers, but you have to remember, you have headwork (valve job) and had to go with 1.75 baffles. It works for you, and I am happy for you. But, OP was asking what the best all around cam was. I side with GEORGEW, Hillside and Sheffer for the Cyclerama 570.
Besides, what point were you actually trying to make? I said I'd choose the Cyclerama 570's over mine, knowing what I know now. The 57's are irrelevant
Old Jan 15, 2018 | 09:54 PM
  #53
Craigmier's Avatar
Craigmier
I got a set of SE 255 cams. Removed from my 110” motor at 900 miles. Great low to mid range power cams. I run them in my 13” RG custom.
msg me if interested.
Old Jan 15, 2018 | 11:56 PM
  #54
nytryder's Avatar
nytryder
Originally Posted by SnoRider
I install TTS cans. I think it was TTS – 100. Supposed to be pretty decent performin cams but nothing like the chart up above shows. I get disappointed when I see others who have been much more successful than me who have 2-1-2 pipes
Not all dynos are the same. Same dyno, different teck different #'s. TTS Tuner and a good dyno tune will likely help. #s on a piece of paper are just that.
Old Jan 16, 2018 | 10:02 AM
  #55
KumaRide's Avatar
KumaRide
The point is, keepin it real
decated header does nothing for performance. At very best, 1-2hp at the very far right. Certainly does nothing for low end.
The 57 sheet has FM jackpot mufflers. My 1.75 fullsac baffles have nothing to do with it. Headwork?
To say 57s are "irrelevant" is an interesting opinion. Depending funds and the rider, that may not be the case. If they ride like me, and the wallet is thin lol, and live in the 2400~2800 rpm range, then the low end gains of the cr570 are less important then someone that lugs at 2k rpm. Dont get me wrong, more area under the curve is always better. However, Im not one to buy into the "best cam", "best oil", "best shocks".... concept. However, I do buy into the notion that several cams work very well in 103's.
What would be interesting is a cr570 dyno with a stock header, stock 103. That may convince me about the "best cam" in a 103".
Old Feb 8, 2019 | 11:31 AM
  #56
32roadking's Avatar
32roadking
Default 103 top
Two the top
Old Feb 8, 2019 | 05:42 PM
  #57
bklynbob's Avatar
bklynbob
Another opinion... You’re not far from Docs performance tuning. Can’t go wrong with an Andrews 48 or a CR570 and a real dyno tune. Throw in a 31 tooth pulley and you’ll be happy with that heavy bike.
Old Feb 8, 2019 | 06:17 PM
  #58
lightweight bob's Avatar
lightweight bob
Default Andrews 48 or 57
I had the same choice with my heavy 2013 Limited and went with the 57's de-catted head pipe, A/C, mufflers, Power Vision and tune. I'm not
disappointed but to do over it would be the 48's. Why - when my not small lady gets on I'd like the torque band a little lower with the stock
gearing.
Old Feb 8, 2019 | 08:26 PM
  #59
dforeid's Avatar
dforeid
Woods 222 or TTS 100. I loved my Woods 222 in the old bike. I stay under 3,000 rpm most of the time and it pulled really well. When you want to heat things up a bit though, it keeps pulling right on up. That was on my old 2012 Limited. I'm on to a 2019 RG now.
goose222
Milwaukee Eight (M8)
Jan 8, 2018 09:46 PM
fuelmoto
Vendor For Sale Classifieds
Nov 20, 2017 02:30 PM
fuelmoto
Fuel Moto / Jackpot Mufflers
Nov 20, 2017 02:28 PM
rubberfrog
Sep 26, 2012 05:37 PM
MACHD03
Apr 30, 2010 04:09 PM
