Rebuilding front shocks
Old Jan 31, 2018 | 07:13 AM
big- mike's Avatar
big- mike
Default Rebuilding front shocks
Ok seeing I have rebuilt everything except the front shocks in my 2010 ultra they are next on the list. Seeing I've never done a set I do have a service manual and I can read my question is do I need any special tools and what are the best springs for a 250 lb man? I home there is a kit that has seals and bushings just not sure on the springs
Old Jan 31, 2018 | 07:41 AM
Cygnusx51's Avatar
Cygnusx51
Well, I believe the fork cap will take a 1-3/8” wrench if you don’t have one of those, be aware to follow the advise in the manual about using an impact gun to remove the bottom damper bolts so that you don’t strip them out. Those will take an Allen bit, I just cut off the short part of the L from a cheap Allen wrench and used the long piece.
HD sells a fork rebuild kit with all of the necessary seals, bushings, damper bolts and crush washers.
It’s suggested to use a fork oil level tool but I simply used a piece of string to measure the air gap when filling the forks back up.
As for the springs, you can get “heavy duty” springs from companies like Progressive Suspension but I don’t know what they’re generally rated for. Take the advise from your other front fork threads though and either upgrade to cartridges or go cheaper and at least get a set of valves like the Ricor Intiminators. I wouldn’t just replace the springs alone and expect to see much difference.
Old Jan 31, 2018 | 07:48 AM
nhrider1's Avatar
nhrider1
Try Race Tech for springs (single rate). They have a sizing chart on the web site. There is a tool available to remove the fork caps (internal). HD has a fork rebuild kit with seals and bushings.
I'm rebuilding mine this winter. Race tech springs and Ricor Intiminators.
Old Jan 31, 2018 | 08:06 AM
big- mike's Avatar
big- mike
Thanks fellas I thought I saw something about a double flat socket for after you get the cap off that holds the spring in
Old Jan 31, 2018 | 10:43 AM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Take a look at this REPORT LINK we did on Front Suspension after extensive testing.
Lots of useful info when to have, including this chart-
Hope this helps.
Cristy
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old Jan 31, 2018 | 11:05 AM
big- mike's Avatar
big- mike
Thank you would you Gus have everything I might need?
Old Jan 31, 2018 | 11:27 AM
DK Custom - ST
Platinum Sponsor
Give us a call here in the office or shoot us over an email and make reference to this post. We will get ya all set up.
Cristy
Old Jan 31, 2018 | 01:55 PM
Scuba10jdl's Avatar
Scuba10jdl
35mm to be precise as it is metric, but a 1 3/8" works nearly as well.
Old Jan 31, 2018 | 07:50 PM
Cygnusx51's Avatar
Cygnusx51
I knew I was close lol.
Old Jan 31, 2018 | 07:54 PM
kel03's Avatar
kel03
Close is good.
