I installed a set of Andrews 57H in my Glide and have a tapping from the breather. I know there can be some throttle body noise with certain cams. Is that what I'm hearing? I just want to know if that is "normal" or if I need to be concerned.
It's hard to hear thru a phone or laptop but noticeable when listening on a speakered desktop or earbuds...Thanks in advance for any insight
Although it sounds like tapping, it's actually sound reverberating within your throttle body that escapes out your intake. I don't really understand why it happens with a more extreme cam over stock, but I know that we all get it once we put higher performing cams in. Others can explain "the why" much better than I can.
I'd agree with reversion, the 57 is famous for it. When I had 57s in my Limited with an open backed Ness Big Sucker AC the noise was maddening. I ended up going back to a stock AC.
John @ Rockout
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
I’m sorry for the possibility of a dumb question, but, do the anti-reversion baffles in Rineharts help with this? Or is it an entirely different scenario? Everybody’s knowledge has to start somewhere.
