Battery replacement
Old Feb 22, 2018 | 03:37 PM
jcarruth's Avatar
jcarruth
Originally Posted by Rob175
I don't know much about batteries but the salesman at my local Batteries Plus Store was touting the lightweight LITHIUM batteries. Is that type sutible for HD's?.....they sure are expensive!....but also feather lite.
They have a strong initial power output, but about a 3X greater discharge rate under a parasitic load, not good for a late model HD with a clock and ECU. I highly recommend Big Crank AGM (Deka).
Old Feb 22, 2018 | 03:40 PM
HKMark23's Avatar
HKMark23
Originally Posted by White Ice
This is my only beef with Yuasa batteries
From http://www.yuasabatteries.com/faqs.
How is Warranty handled on a Yuasa battery?
Yuasa Battery, Inc. does not handle warranty issues directly. All inquiries should be directed to the dealer where the battery was purchased. The dealer's distributor sets the warranty period and handles all warranty claims. The warranty time frame and terms are not specified by Yuasa.
From Amazon
Product Warranty: For warranty information about this product, please click here [PDF ]
This is the last paragraph from the pdf
Manufacturers’ warranties may not apply in all cases, depending on
factors such as use of the
product, where the product was purchased, or who you purchased the product from. Please
review the warranty carefully, and contact the manufacturer if you have any questions.
Seems to be a bit of a run around.
FYI
http://www.yuasabatteries.com/pdfs/N...o-customer.pdf
Also:
https://www.yuasa.co.uk/info/quality...nty-explained/
We get a year in Canada:
https://fortnine.ca/en/yuasa-gyz-hig...e-free-battery
Old Feb 22, 2018 | 03:45 PM
grbrown's Avatar
grbrown
Wink
I have a Lithium battery in my old Glide, but the only reason is that I have moved it under the seat which is a confined space. I wanted a fairly small battery able to turn over a 107" engine and the Li type gives me a serious output in CCA terms. I don't use Li on any other vehicle and don't plan to.
Old Feb 22, 2018 | 07:27 PM
grizzlygar's Avatar
grizzlygar
I just installed the yuasa 500cca battery in my 2013 ultra limited , man does it ever crank it over.
Old Feb 23, 2018 | 08:29 AM
Rob175's Avatar
Rob175
Can a AGM battery be charged/maintained using a BatteryTender or Battery Minder charger/maintainer? I still have the HD stock battery in my Ultra Limited and use those charger/maintainers now.......will they also work on a AGM style battery?
Old Feb 23, 2018 | 09:03 AM
grbrown's Avatar
grbrown
Thumbs up
Yes - well all mine do!
Old Feb 24, 2018 | 04:08 PM
Rob175's Avatar
Rob175
Thanks....
Old Feb 24, 2018 | 04:45 PM
FXDXTSport's Avatar
FXDXTSport
Originally Posted by st john
I went with the Throttle-X American Made battery offered on Amazon three years ago. I will report back on how great it is when it goes bad. I ride in Arizona heat and I do not use a battery tender.
I'm due to replace the OEM battery in my bike. I put a big crank in my last bike when I repaced the OEM. I'm now considering this battery
Amazon Amazon
118 reviews and all but 4 are 5 star. The rest are 4 star. 600 CCA. $30 more that the big crank but less than the Yuasa,
Old Feb 25, 2018 | 07:22 AM
Killa's Avatar
Killa
Originally Posted by jason605
I just replaced the battery in my 13 fltrx with this
Renegade RG30L-WS 12 Volt 30 AH Ultra Premium Wicked Start 600+ CCA Battery
perfect fit. I order from their website for 109.00 shipped.
I just installed this one 2 weeks ago, hope it last. Really spins the engine
Old Feb 25, 2018 | 07:49 AM
Buck05's Avatar
Buck05
Curious why you won't use lithium batteries on other vehicles. Cost? Fire hazard? Life span?
