Idle shaking
Old Feb 17, 2018 | 05:51 AM
K Melancon's Avatar
K Melancon
Compared it to another StreetGlide? It it doing more than when it was new? Have you checked your motor mounts?
Old Feb 17, 2018 | 07:55 AM
whyrzwaldo's Avatar
whyrzwaldo
IF this is legit......
Agree with other posters...HUGE difference when front brake is engaged -vs- not engaged at a stop...totally different in transferring the shaking right up the forks!
Barring that...the motor mounts would be the next thing to look at.
Old Feb 17, 2018 | 08:02 AM
CrBear's Avatar
CrBear
You think the Street Glide shakes.. you should try a Dyna ! ha
My 14 shakes pretty good at idle but not like my Switchback did.
I kinda like it though...
Old Feb 17, 2018 | 08:04 AM
CrBear's Avatar
CrBear
Oh and like others have said..... The wife says its the "gift" that keeps on Giving !!
Old Feb 17, 2018 | 12:01 PM
wscott's Avatar
wscott
Originally Posted by gdragon
My 2014 Street Glide shakes like crazy at idle. Bike runs perfect but the shaking is crazy when stopped. Any ideas? Is there a fix?
1st to keep in mind is it's normal for many HD's to experience engine shake @ idle,esp with rubber mounted motor so maybe your just used to that,dont know if thats the case or not here.
With that said if you have stock fuel calibration then it can be the excessive lean idle fuel calibration making motor idle rougher then it should.
I had the same issue with my bone stock 09 HD,i installed NightRider Enrichment Resistors to fatten up overall fuel mix a bit and found when testing that the 50% enrichment position smoothed out the idle enough to reduce shaking some @ idle along with also eliminating a slight lean surge it had when at steady state cruise a light throttle position too.
25% position wasnt enough enrichment to help and 75% enrichment position didn't seen to make it run any smoother at idle or run better when riding then 50% enrichment position did which is how in ended up @ that setting/position.
Those 2 improvements overall engine perf were well worth the cost & 1-1.5 loss in mpg post richening up the fuel mix a bit.
But i didnt feel an real noticeable improvement/reduction in heat felt from motor in traffic or at cruise or reduction in oil temp at all post richening fuel mix a bit.
Scott
Old Feb 17, 2018 | 12:09 PM
TriGeezer's Avatar
TriGeezer
OMG! My ‘12 shakes a lot a idle too. Does that mean it going to fly apart?
Next, someone will complain their touring bike is hot in stop and go traffic, and there’s no place to put the gas cap at the filling pump.
Old Feb 17, 2018 | 01:02 PM
todd-67's Avatar
todd-67
My guess is that he just got his first HD. Now after the bashing he isn't coming back. I get asked the question a lot by non harley riders or non riders. It always "damn that thing shakes a lot. Doesn't that get old after a while?"
Old Feb 17, 2018 | 01:14 PM
Modo's Avatar
Modo
Hell I had to ask a few people and call the stealership after I got my FLHX, I've only ever ridden Softails so when I moved over to the FLHX I was like holy **** is thing going to explode? I guess people think they are being crafty or something. I'm these same guys ask dumass questions everyday.
Old Feb 17, 2018 | 01:38 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Yeah trade it in for a pink metric girls bike. You will be happy and we can see you coming and keep as much distance as possible.
Time to go back to your grandma's basement. Too much sunlight is harmful.
max56's Avatar
max56
Veteran: Coast Guard
I once had a Goldwing and I was in a parade line next to a Harley touring bike. I looked over at his bike and saw the handlebars shaking quite a bit. That's when it occurred to me that he was on a real motorcycle....and I was on a two wheeled car. I got rid of the Goldwing and bought a motorcycle.
