fp3 tps calibration...
I sent an email to V&H and have yet to receive a response...weird.
anyhow..those that use the fp3..what does yours show.
thanks
if so try this.......
THROTTLE PROGRESSIVITY
1) Turn key/handlebar switch both on and connect to FP3 app
2) Go to 'View/Edit Maps'
3) Select map highlighted in blue (map currently flashed to bike)
4) Go to 'Air and Fuel', then 'Throttle Progressivity'
5) Turn wheel to adjust the setting to ‘Aggressive’.
6) Hit "Back" arrow at the top of the screen and press 'Continue' when it gives you the warning.
7) Press 'back' arrow one more time and look for a lightening bolt logo in the upper right corner.
8) Press the lightening bolt and follow the in-app prompts to flash the new changes to the bike.
5) Turn wheel to adjust the setting to Aggressive.
when monitoring the tps I see it is at 4 at idle.
