The OP asked if the Mityvac , (or similar) , will bleed/flush bleed the Hydraulic clutch ... Yes it will.. Same procedure.....
But,, be aware the bleed nipple for the Hydraulic clutch is smaller than the Brake caliper bleed nipple ...
The Mityvac , (which I have), has adaptions,, connections, and a piece of smaller clear tubing, (in the kit), that will fit the smaller hydraulic bleed nipple ....
[QUOTE=Bone Doc;17134072]I'm the former.
You only need to be pissed if your wife, girlfriend or significant other finds you've been checking out that website.
If you can't beat it you probably need the Pos-T-Vac.[/QUOTE]
Are you sure you are the former?
speed bleeders are good. just need to build pressure in the lines. i just installed some. they didn't get all the air out after a bottle of fluid. had to ziptie the lever to get all the air out.
