Fork oil vs riding style
Old Mar 5, 2018 | 04:29 PM
dandrumheller's Avatar
dandrumheller
I went from presumably never changed stock fork oil in my 11 limited to 15wt belray last summer.
Noticably more jarring ride (GoPro in the fairing mount is a no go now) on rough roads. Feels more planted to me when maneuvering though, and brake dive is MUCH less. Overall definite improvement. Gonna see of it stays this firm with more miles - if so will probably do a blend to go to something like 12.5wt on next change.
Old Mar 5, 2018 | 05:13 PM
Notgrownup's Avatar
Notgrownup
Yeah I am 275 lbs and 15wt was a bit stiff, mixture of 15 and 10 was better...
Old Mar 5, 2018 | 06:22 PM
67Shuv's Avatar
67Shuv
Sounds like a mix of 10/15 will get me where I'm wanting. I'm hearing of guys running up to 40w and 50w though. That has to be miserable. I'm 240lbs and the bike is not usually loaded real heavy but it's pretty much never empty. I bring tools and a tiny jump box everywhere I go.
So so it's looking like I'm about to tear down the forks, inspect wheel bearings, neck bearings (just by feel, not disassembling) inspect bushings, changing seals and oil. If it were closer to time for a tire I'd probably go ahead and do tires and fresh wheel bearings while I was there. The brakes also deserve a good inspection too.
Old Mar 6, 2018 | 05:11 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Caveat emptor with fork oil viscosity. There is no standard, so one's "10" might be the same as someone else's "30".
For example:
https://www.reddirtriders.com/storag...ensionoils.pdf
Old Mar 6, 2018 | 04:29 PM
xcbullet's Avatar
xcbullet
Looking at the link (foxtrapper)- red line yellow looks like a good one to try. Maybe time after next as I already have Lucas lined up waiting to go in next change..
Old Mar 6, 2018 | 08:29 PM
bikerlaw's Avatar
bikerlaw
I use the Harley branded fork oil. I mix standard weight and heavy duty weight at a 50/50 mix. I'm very happy and the slightly firmer ride works great in conjunction with my lowered front end.
Old Mar 7, 2018 | 07:36 AM
btsom's Avatar
btsom
Doubt that I am the first one to wonder about this, anyone KNOW the difference between fork oil and engine oil? In other words, is there anything in engine oil that would harm seals or valves in a fork? Fork oil seems to be single weight, you get more damping at 40 degree than at 100 degrees. Would something like 10W-30 engine oil make the ride more consistent over a wide range of temperature?
Old Mar 7, 2018 | 08:02 AM
foxtrapper's Avatar
foxtrapper
I've got and had bikes that called for engine oil in the forks. It will work.
Many claim that fork oil has anti-foaming properties above and beyond motor oil. Perhaps true, perhaps not. I've never seen proof of the claim.
If you google the likes of "fork oil vs engine oil" you'll find many discussions and a few articles on the subject.
Old Mar 7, 2018 | 12:31 PM
Notgrownup's Avatar
Notgrownup
Detergents and friction additives etc...once the viscosity is shot it’s all the same pudding...Synthetic stuff seems to do a bit better.
Old Mar 7, 2018 | 06:51 PM
Cossack84's Avatar
Cossack84
There is absolutely NOTHING wrong with motorcycle "brake diving". If you set your front end up so stiff that it does not lower/compress caring up 90% of the weight during hard braking, then you will have LESS traction not more!
Guys, 1000 pound bike shifts most of the weight to the front under hard braking, of course forks will compress to the max when you double the weight that they carry. Or even under normal decel weight goes to the front and forks have to compress to accommodate it.
This front end dive nonsense has to stop, please for the love of all that is holy. Again its normal.
To answer op question I find that synthetic ATF works a treat in forks and shocks. But do pay attention to level you fill them to, because amount of air that is left inside has big effect on how forks act.
