Sert Plug
Old Jun 20, 2007 | 09:17 AM
nelsonrl's Avatar
nelsonrl
Default Sert Plug
So, where do you plug the SERT in on the Ultra Classic? What all has to be removed?
Old Jun 20, 2007 | 09:40 AM
Harleypingman's Avatar
Harleypingman
Default RE: Sert Plug
Remove the right saddlebag, then the right side cover. There is a data link clipped to the right of the ECM. The cable with the serial connector end plugs into the data link. If you are wondering where to plug the SERT into, it may be that more time should be spent reviewing the SERT's Owner's Manual because it is possible to screw up the use of the SERT resulting in a corrupted ECM totally disabling the bike.
Old Jun 20, 2007 | 09:53 AM
nelsonrl's Avatar
nelsonrl
Thanks for the info. I will read the manual when I get it. I should have been a little clearer. I am ordering a SERT and do not have anything to read yet.
Old Jun 20, 2007 | 10:04 AM
Harleypingman
Good for you!!! The SERT was designed for tuning the bike without a dyno by an owner; if you read the Owner's Manual a couple of times you will be able to make safe adjustments to the ECM, ride the bike with the SERT connected and do data runs to see if the changes favorably changed the bike's performance or not. If you have or acquire a Daytona Twin Scan II+, you wil be able to collect air/fuel data and be able to do what is done on a dyno only instead of the rear wheel turning a drum on a dyno, your rear wheel will be turning on a road.
Good luck.
Old Jun 20, 2007 | 10:48 AM
nelsonrl's Avatar
nelsonrl
Anyone know of a SERT manual online anywhere?
Old Jun 20, 2007 | 11:42 AM
04harleyboy's Avatar
04harleyboy
Don't forget to order the cables with it, they no longer come with the SERT.
Old Jun 20, 2007 | 11:50 AM
nelsonrl's Avatar
nelsonrl
Good point - will probably order from Chicago unless someone can recommend a better source. They are considerably cheaper than my local dealer.
Old Jun 20, 2007 | 12:18 PM
bluesgub's Avatar
bluesgub
Comes with the unit when you purchase the SERT.
Old Jun 20, 2007 | 01:28 PM
nelsonrl's Avatar
nelsonrl
I was looking for something I could read before the unit arrives.
Old Jun 20, 2007 | 02:32 PM
Biggzed's Avatar
Biggzed
PM me with your e-mail address. I have it on a pdf.
