broken Intercom/CB knob?
Old Mar 11, 2018 | 01:31 PM
ORradtech's Avatar
ORradtech
Trust me ... the silicone will not hurt a thing as it is non-conductive ... As the OP stated he's not going to use it again ... If you're going to take it apart just buy the part and fix it properly
Not concerned electrically. More concerned with it causing mechanical issues with other switches. Might be sealed and not a concern, idk. I do know that crap just gets everywhere and is hard as heck to get off/out.
Old Mar 11, 2018 | 01:33 PM
Uncle Larry's Avatar
Uncle Larry
It's all in how you use it ... It's not a big deal to be careful.
Old Mar 11, 2018 | 01:59 PM
GhostRiderFLHTC's Avatar
GhostRiderFLHTC
Originally Posted by ORradtech
You didn't say if the radio started working again. You may not use PTT but if affects the radio it could do it again.
I would not squirt silicone into the switch pack. Tape it or tale it apart and stick something inside. If the radio works and function is unimportant then super glue might work just fine.
Radio works fine. I will try to find a plug that fits tight for now I covered with tape. Replacing the switch most likely involves taking the fairing too so the trouble is too much.
Cheers!
Old Mar 11, 2018 | 02:01 PM
GhostRiderFLHTC
Originally Posted by trigeezer
dang it ghostrider...your avatar...i’m getting dizzy.
GregGillette
Mar 23, 2022 10:14 AM
GhostRiderFLHTC
Electrical/Lighting/Alarm
Mar 10, 2018 01:52 PM
Stickman81
Sep 6, 2017 01:47 AM
akakillroy
2014-2024 Touring Models
15
Oct 4, 2015 09:32 PM
skipper469
Feb 20, 2010 12:49 PM
