I bought a non abs enforcer front rim off a 2015 SG, it will be going on my 13 SG . It is a complete wheel except for rotors. question is what rotors do i need to order? Is it as simple as ordering stock rotors for the 15 enforcer or do i need a 2013 style rotor.
Using Ronnies HD parts finder, the front brake calipers are the same model numbers for the 15 and 13 SG. (43027-08 and 43028-08), but the rotor numbers are different, so, I'd probably get the one for the new wheel (41500017).
Rotors for the Airstrike wheel will not fit on an enforcer wheel, both are 11.8" but with different bolt pattern. As stated before go with rotors for your new wheel.
