No high beam
Old Mar 21, 2018 | 02:19 PM
Luther A Mennes's Avatar
Luther A Mennes
6th Gear
Default No high beam
I have no high beam on this 95 Electra I just bought seems like I'm not getting voltage at switch when I turn on high beam and on low am only getting 5.42v is this the switch or is it further down the wire as a short. Also if it is the switch where can I find decent parts online. Thanks
Old Mar 21, 2018 | 05:26 PM
grbrown's Avatar
grbrown
Have you checked or changed the bulb? Or are you saying you've done that and found no power to high beam? An electrical problem could be in the lefthand switch-gear or wiring. It is an unfortunate fact that owners often trap a wire when refitting the controls, after a handlebar switch, for example. It takes a bit of care and effort to avoid trapping and damaging a wire!
For future reference we have a dedicated Evo section, where you can meet up with plenty of felloe owners.
Old Mar 21, 2018 | 06:48 PM
Luther A Mennes
6th Gear
Yeah I changed the bulb but remembered that It was not working before guy I bought it off said he just changed the handle bars. When I removed the housing to check voltages I found that I wasn't getting any volts when I switched it to high beam from low.
Old Mar 21, 2018 | 07:33 PM
14GuineaPig's Avatar
14GuineaPig
You should have 3 wires connected to the Hi/Lo switch.
BE (Blue) - 12 V Power
Y (Yellow) - Low Beam
W (White) - High Beam
You can also take a look at the 15 Amp "Lights" fuse. Make sure there's no corrosion.
Here's a link to a parts finder that's great for getting part numbers, then you can order from a dealer or google/ebay the number.
https://www.dodgecityharleydavidson....95)//HANDLEBAR_
You can also get wiring diagrams at Harley Davidson's Service Info Portal
https://serviceinfo.harley-davidson.com/sip/index
Just do a search for "1995 wiring"
Old Mar 21, 2018 | 07:39 PM
Luther A Mennes
6th Gear
Thanks guys really appreciate this I'll keep ya posted
Old Mar 22, 2018 | 09:17 AM
grbrown's Avatar
grbrown
Red face
Unfortunately electrical problems after a handlebar change are common all around HDF. There are some ham-fisted people out there! Hopefully that is where you will find the source of your problem. Fingers crossed!
Old Mar 22, 2018 | 09:21 AM
RK12's Avatar
RK12
CHeck your fuse. If burnt, then you have wires grounding out. Had the same issue on a RK,
Old Mar 22, 2018 | 11:29 AM
grbrown's Avatar
grbrown
Cool
A '95 Glide doesn't have fuses, only circuit breakers.
Old Mar 22, 2018 | 01:30 PM
Luther A Mennes
6th Gear
My big problem is finding an owners manual and wiring diagram. Cannot find one anywhere. May have to break down and buy a clymer
Old Mar 22, 2018 | 01:32 PM
Luther A Mennes
6th Gear
Even if I could find a diagram of the electrical panel
