won't start
Old Apr 6, 2018 | 11:23 PM
reedjames's Avatar
reedjames
Stage IV
Default won't start
fire to coil but no spark to plugs
Old Apr 7, 2018 | 07:21 AM
Vernal's Avatar
Vernal
Welcome to the Forum from Utah!
Always include the model and year of the bike your working on.
Old Apr 7, 2018 | 09:27 AM
kojak's Avatar
kojak
Bad coil?
Old Apr 7, 2018 | 04:11 PM
woodthumb2's Avatar
woodthumb2
not likely.. but i am far from an expert.. however i have seen some weird things work out with the guys i ride with from time simply by disconnecting battery negative for few minutes.....worth a try especially if u r stranded..these ecms control almost everything these days and doing this will reboot them....... then off to the stealer u go to find out why..
Old May 29, 2018 | 06:22 PM
reedjames's Avatar
reedjames
Stage IV
Default 01 dyan low rider
got fire to coil but no spark at plugs
Old May 29, 2018 | 07:19 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Welcome from western Michigan, the crank position sensor on the left front of the engine case "reads" the notches on the flywheel and on a predetermined spot on the fly wheel a signal is sent from the CPS/CKP to the ignition module to the coil to fire the spark plug/s. Others on this forum have figured out a "normal" signal voltage from this sensor. I would start there. Have you done anything to the bike before this happened/ If so review what was done to see if it affected the firing circuit.
Old May 29, 2018 | 07:46 PM
multihdrdr's Avatar
multihdrdr
I say that every time I walk up to it
"Want Start"... (I learned that from my Native American friend)
txphatboy
Oct 6, 2015 08:07 PM
Tattooman67
Feb 5, 2014 11:01 PM
Jesseluke22
Apr 22, 2013 10:01 AM
RodeoHard
Apr 25, 2012 06:15 PM
thebanditathome
Engine Mechanical Topics
Sep 12, 2011 11:22 PM
