16 Road King
Relatively new to the forum and new to the Road King. Only been riding about 7 years. I just upgraded from an 09 Fatboy to a very gently used 16 Road King. It's pretty much stock, except for the new seat and highway pegs I added. I love the bike, but it sounds like a lawnmower and seems to lack some of that "oompf".
Talking to some friends, they've suggested a "stage 1 upgrade", but I'm not 100% clear on what all that entails.
SO, here's my question. I've saved up about $2,500 specifically for the bike. What upgrades do you all think I should do (keep in mind that I'm a rookie wrench turner and will probably need to pay for installation unless it's super easy)?
Here were my thoughts:
V&H Fuelpak F3 - $399.99
V&H Power Duals (head pipe, i think) - $599.99
V&H Eliminator 400 slip ons - $499.99
Arlen Ness Inverted Deep Cut Air Cleaner - $377.96
Am I on the right track? Should I (do I need to) do all 4? Is there something else I should be looking at?
Any advice would be appreciated!
https://www.fuelmotousa.com/contact....IMITED%20FLHTK
I'm sure others will chime in to suggest better Stage I components. As mentioned, Fuelmoto is a good source to call and their site has some dyno charts of different configs to compare.
Install for a stage 1 is pretty straight forward and can be done in your garage without a lift, a good socket set is all you really need. The hardest part will be getting the old exhaust off and that shouldn't be that bad. Make sure you get some new exhaust gaskets.
Your parts listed are great if that's what looks good to you and will perform well together.
V&H Fuelpak F3 - $399.99 :: This is the tuner portion, remaps the engine for the additional parts
V&H Power Duals (head pipe, i think) - $599.99 :: your stock head pipe has a catalytic converter in it, lots of options and this choice works fine.
V&H Eliminator 400 slip ons - $499.99 :: the slipon mufflers. again, tons of choices with differing sounds.
Arlen Ness Inverted Deep Cut Air Cleaner - $377.96 :: you guessed it, more choices so go for what you like to look at.
If you can, try and get out to a bike night and listen to some exhausts and go from there.
Remember, it's your money so buy what you like
As open as the stock air cleaner is and with stock heads and cams you could get away with just replacing the stock element with a K&N.
After a year, I wanted to do a stage 1 and was looking at the VH head pipes and FP3. After months of debate, I went with a stage 1 set up from Fuel Moto. I got their intake, 2-1 road and track jackpot pipes, and a Power Vision tuner. Installed it in my garage in a few hours (multi tasking). I dont remember the exact cost, they were having a deal, but I'd say in the $12-1400 range. You could use the change to do bars or LEDs.
I could not be happier with current set up I have now. The performance is a very noticeable upgrade, they sound and looks are great (imo) and the customer service from Fuel Moto is 2nd to none. I've talked 2 of my buddies into going thru them and they share the same feeling I do.
Just my thoughts....
