All bore 107
Old Apr 27, 2018 | 11:54 AM
04glideTC's Avatar
04glideTC
Default All bore 107
I know rev performance has a bolt on kit. My real question is could i use 4.125 s&s cylinders and a different piston or same.
my plan was to build a 107 all bore with 110 heads.
11.0 compression with s&s 625 cam.
any suggestions?
Old Apr 27, 2018 | 01:41 PM
InthewindMN's Avatar
InthewindMN
Not sure what your asking. A 107 uses 3.927” pistons. The 4.125 is for 117 or 124, both require bored out cases.
110 heads have a larger combustion chamber than a 103 and the pistons will have to match in order to build compression.
Old Apr 27, 2018 | 02:59 PM
04glideTC's Avatar
04glideTC
well a 107 all bore is 4" stroke x 4.125 bore. Yes same as 117. Cases will be bored. I want to keep the 4" stroke.
Old Apr 27, 2018 | 03:45 PM
LazySundays's Avatar
LazySundays
any suggestions?
Try posting this in the engine section. There are some very experienced builders over there who should be able to help you.
I seem to recall somebody (DJL maybe?) was running a similar combo. He might see the post over there and chime in or you can try searching "All Bore 107" and see if the member I'm thinking of pops up.
ardbark
Oct 4, 2020 05:28 PM
FXWGG
Jul 12, 2018 10:08 AM
FL-kruzen
Oct 19, 2012 01:48 PM
txphatboy
Mar 5, 2012 06:29 PM
hadlje
Apr 27, 2009 05:14 PM
