steering head bearings
Old May 16, 2018 | 07:58 PM
pinn600's Avatar
pinn600
Default steering head bearings
Hello forum,
Over the past while I had began to notice that my 96 RK had started to get a little unstable while passing trucks and on some patchy roads.I had replaced tires a little while before noticing this.I just replaced swingarm bushings thinking this might have been the problem but still shaky.I had heard a lot of discussions about steering head bearings needing adjustment and since I am approaching 60000 I thought I would check it out.I found that the adjusting nut is completely tightened down as far as it will go and the forks turn freely and I feel like there is still play in the triple tree.The fact that there is no adjustment at all concerns me.Anybody got any opinions or insights on this?Any help will be appreciated.
Thanks
Old May 16, 2018 | 09:02 PM
Guntoter's Avatar
Guntoter
Make sure you follow the procedures in the manual to do the adjustment. You will not be able to turn the adjuster without loosening the tube pinch bolts and top tree center nut. Also Snap On sells the proper tool to turn the adjuster which is lots easier.
Old May 16, 2018 | 09:46 PM
pinn600's Avatar
pinn600
Followed manual exactly as it instructed but adjuster is turned down tight,will back off but no farther down
Old May 16, 2018 | 09:54 PM
Kingglide549's Avatar
Kingglide549
I would install a touring link or something like it B4 ANYTHING else (if you have all new swingarm bushings)
It is one of the best mods i ever did.
Old May 17, 2018 | 08:44 AM
btsom's Avatar
btsom
Can not believe you have run out of threads on the center post UNLESS a bearing has disintegrated. Time for a disassembly and inspection of the center post, bearings, and bearing races. Replace parts as necessary. Have you ever greased the steering head? I grease mine on every oil change and fall away has remained unchanged since the 5000 mile adjustment, now above 90,000 miles.
btsom's Avatar
btsom
Old May 17, 2018 | 04:03 PM
pinn600's Avatar
pinn600
Thanks btsom,
Tend to agree that something must be wrong even though the forks still move freely,but yes i have greased the bearings.don't know just yet but it almost looks like too much space at bottom of neck to lower tree.guess just gonna have to see.
Dancemax
Jun 8, 2014 08:28 AM
danzio
Jun 19, 2013 11:35 PM
Luxe
Feb 20, 2008 11:38 PM
vulhalla
Aug 26, 2007 10:19 PM
bajabob
Mar 11, 2006 07:10 PM
