steering head
Old May 17, 2018 | 06:13 AM
pinn600's Avatar
pinn600
Default steering head
96 Road King with 58000 miles-the steering head bearing adjuster is tightened down as far as it will go and there is no drag on bearings-thinking that adjustment might be needed since handling problem around truck turbulence has become an issue-wondering why there might be no adjustment left-instability seems to be in front endand have already replaced swingarm bushings
Old May 17, 2018 | 06:19 AM
Kingglide549's Avatar
Kingglide549
A big truck will always give you a push or shove.
DO you have a 3rd link on of sorts?
Old May 17, 2018 | 07:13 AM
Ed Ramberger's Avatar
Ed Ramberger
Just making sure you're nut just trying to tighten the nut down thinking that is the adjustment.
Old May 17, 2018 | 08:29 AM
larsfum's Avatar
larsfum
You need to conduct a fall away test as described in the service manual. Then you can make the adjustments from there. You are always going to get a but of turbulence from a truck.
Old May 17, 2018 | 04:06 PM
pinn600's Avatar
pinn600
no third link but this problem just started recently
Old May 17, 2018 | 04:09 PM
pinn600's Avatar
pinn600
thanks ed,no i'm trying to tighten the adjusting nut under the upper tree
Old May 17, 2018 | 04:10 PM
pinn600's Avatar
pinn600
this is more than normal turbulence i have encountered on this bike
Old May 17, 2018 | 09:25 PM
smat45's Avatar
smat45
Kind of just went through this...
08 SG...58k
Replaced the swing arm bushings...bagger brace...new tires...Ohlins front and back...
Still did the hula hula in sweepers...
Loosened up the adjuster in the neck...(it would be a lot easier if there was a zerk fitting on the top...but it's only the bottom..) .but all the grease is gone...and you have to fill that whole neck to get grease up there...you can do it...butt it's a PITA! Not the work...just the inherent mess...all that frick'n grease ooz's out over time...so you have to be mindful of it catching on you lower tree and wiping it out from the inside...
It's almost impossible to get grease to go all the way up the tube before it starts squirting out the bottom... so a tip I got from a member here (can't remember his name...Thanks bro!) Tie a piece of small diameter rope around the bottom of your neck (where the grease squirts out) and force it all the way up there...(I went through nearly a whole tube)...turned the wheel while doing it...it was asking for more...it was messy...grease always is...
Then try your adjustment...should have a lil adjustment (mine did...world of difference)
Good luck...hope it works instead of having to replacing your steering neck bearings
smat
Old May 17, 2018 | 09:44 PM
bikerlaw's Avatar
bikerlaw
There is so much wrong with this post......
Old May 18, 2018 | 05:47 AM
pinn600's Avatar
pinn600
thanks smat,i will give that a shot before tearing it down
