ABS delete
Old May 18, 2018 | 12:22 AM
c4mac's Avatar
c4mac
Originally Posted by FXDXTSport
I think you need to check again. P/N 71621-08. Brake light switch turns off ABS and turns on rear brake light.
I see it in my parts catalog, saw it earlier today and assumed it was for the non-ABS models. Just checked my service manual and sure as **** the stoplight switch is part of the Road King Classic Right Hand Control! Hell, this project just got simple. Thanks FXDX!
Old May 18, 2018 | 12:30 AM
TriGeezer's Avatar
TriGeezer
Originally Posted by Cab Lizzard
Think about this before you delete anything.
Some states check the ABS for their state safety inspection in order to get plates renewed.
If you take it to a dealer to be worked on and they see it has been disabled it would be against federal law to work on said bike. Much the same with emissions also.
So, some states do a safety inspection of a feature that is optional? And it’s against federal law to work on it? Sorry, but I find both hard to believe.
Old May 18, 2018 | 04:14 AM
Lostrider's Avatar
Lostrider
I agree with you there. I have a 2012 as well and while I am non ABS I can clearly see the ABS light in my instrument cluster. Obviously I do not have the ABS visible on my wheels but in the end it is an option that you do not have to buy so therefore I find it hard to believe that any state would enforce anything while inspecting the bike. I live in a state that does require a yearly inspection. It is a safety inspection and the only check concerning brakes is pad wear and function, not optional features.
Old May 18, 2018 | 07:17 AM
14GuineaPig's Avatar
14GuineaPig
Well now that everybody knows where the front brake light switch is, I have a question. If all you do to a bike like the OP's 2012 RK is change the brake lines to non-abs lines, thus by-passing the abs module, would the ABS light stay on. I'm not sure exactly how it works, but I know it does check that the wheel speed sensors are working as the bike hits 3 mph. So without changing anything else would you get an ABS error. I would think that you could plug the openings on the abs module and not get any errors.
Old May 18, 2018 | 09:45 AM
KCHD1's Avatar
KCHD1
It would be "against Federal Law" Is there anything the Feds don't stick a finger in ( I never heard of such a law). I also can not think of any shop or even a dealer who would first of all realize you deleted it much less give a crap. And I also do not know of many shops that would turn the work away? They may not want to ever work on your brakes that I could understand.
Old May 18, 2018 | 11:42 AM
dribble's Avatar
dribble
Emissions are covered by both state and federal law. ABS is required on most bikes sold in the EU. I'm not aware of any law in the US that requires ABS on motorcycles. In fact many bikes still don't have it. It would be no more illegal to delete than it would to change out your seat.
Old May 18, 2018 | 03:56 PM
nytryder's Avatar
nytryder
Originally Posted by 14GuineaPig
I don't know why you would have to change the front brake light switch. ABS & Non-ABS use the same part which is in the hand controls.
https://www.dodgecityharleydavidson....SWITCHES,_HAND
All you need is a short brake line to jump around the module (I think) and you should be good to go. If it were me I'd just buy a new module and do it right. I actually have seen one that was done that way but have no idea how well or if it worked, Good luck!
Old May 18, 2018 | 05:10 PM
14GuineaPig
Thanks for the info. I was just speculating about whether or not the ABS light would come on if all you did was replace the ABS brake lines with Non-ABS lines and plug the ABS module. I have no intention of disabling the ABS on my 14 FLHTK nor am I advocating that the OP disable his. My original reply was to let the OP know that the ABS & Non-ABS models use the same brake light switch.
Old May 18, 2018 | 05:55 PM
Campy Roadie's Avatar
Campy Roadie
Pull the abs fuse and the light can't come on. No power to that system.
Old May 18, 2018 | 06:15 PM
ORradtech's Avatar
ORradtech
I saw that bypass on this forum somewhere. As I recall it worked well. That is what I'd do if I had AND and it failed.
As for buying a new module, that's not gonna happen. HD has made the new ones dealer only. EBay does have a few used ones but I'd rather bypass than gamble on a used one, as prone as they are to failure...
