Check engine light-code P1356 Help
Old May 23, 2018 | 04:10 PM
Cozz's Avatar
Cozz
Default Check engine light-code P1356 Help
So...I was out on an excellent ride this morning and I get a check engine light. Pulled the code and it’s P 1356 - rear cyl. No combustion. Bike ran great, no misfire, no stumble, no nothing. It did seem to take just a bit longer to start than normal. The cel does come and go, but it’s on more than it’s off. What does all this mean?
Old May 23, 2018 | 04:28 PM
Keithhu's Avatar
Keithhu
https://www.google.com/search?q=harl...firefox-b-1-ab
Old May 23, 2018 | 05:01 PM
Ed Ramberger's Avatar
Ed Ramberger
That can be a nuisance code or it can be real. There were several factory calibrations that were too sensitive with ION sense and would throw that code. That code can also be thrown if there is a true non-combustion event.
There were also calibrations on the original EFI tuner that would throw that code a lot - they were the ones with HTCC heads.
Can you provide a complete description of the bike, any and all engine or exhaust mods, etc.
Old May 23, 2018 | 06:22 PM
Cozz's Avatar
Cozz
it’s all stock, except for slightly free er flowing 2012 RK mufflers. 2004 Ultra. Spark plugs have a couple thousand miles on them. Plug wires are original and most likely need to be changed. No drive ability problems at all. Bike ran great all morning.
Old May 23, 2018 | 06:32 PM
Ed Ramberger
What brand plugs? That can cause it.
Also, that is the vintage where many revised cals were released for things like false misfire.
Old May 23, 2018 | 06:48 PM
Cozz's Avatar
Cozz
stock hd plugs
QC's Avatar
QC
Plug wires is first thing I’d check.
Old May 23, 2018 | 08:24 PM
Ed Ramberger
Since this is a new problem and the plugs were just changed, I would agree and change the plug wires first then monitor. If it still occurs let us know. Also make sure you didn't get anything such as anti-seize on the porcelain that would cause tracking down the plug.
Old May 23, 2018 | 09:24 PM
Cozz's Avatar
Cozz
I’ll clear the code , change the wires and we’ll see what happens.
Old May 24, 2018 | 08:44 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I had an 04 Electra Glide and I would get that code at least once a month. It drove me nuts because in the 6 or 7 years I had the bike I checked everything I could think of never did figure out why it kept popping up. I have heard others say its a "phantom code" on certain year bikes. So after a while I just got used to resetting the code and ignoring it.
