Locktite vs. teflon tape
Old May 29, 2018 | 10:14 AM
  #41
stixvrad's Avatar
stixvrad
Originally Posted by 07_Dyna
OK - I'll use blue locktite (NOT red!)
How can I deal with the stuff setting up too quickly?
Oh, and what is a good way to remove oil from the bottoms of bolt holes if you don't have an air compressor?
Tanks for your experience. As I said, I've never worked on harleys much.
" What is a good way to remove oil from the bottoms of bolt holes if you don't have an air compressor"
A spray can of carb cleaner or brake clean with the tiny red straw stuck down in the hole and spray away. Just avoid getting either on painted or plastic surfaces.
Old May 30, 2018 | 09:24 PM
  #42
martinj's Avatar
martinj
Originally Posted by AliensilverFXDBI
The threads seal themselves. The tape just prevents the threads from galling before they're tight enough to seal. But you are correct, they're for pipe threads AKA tapered threads
No. They don't. Apparently you've never worked with natural gas or LP gas. It'll leak right through the threads unless some sort of sealant is used.
Old May 30, 2018 | 09:29 PM
  #43
MotoJockey's Avatar
MotoJockey
Or eyeballs....... Burns like hell!
Ask me how I know.......
Old May 30, 2018 | 10:19 PM
  #44
d_slat's Avatar
d_slat
This is not true most of the time. Dryseal pipe thread is designed to seal all by itself, but standard run of the mill npt pipe threads are NOT self sealing, and the tape or dope fills the void and creates the seal.
Smogbob
Nov 16, 2016 06:25 AM
deadhawg
General Topics/Tech Tips
Oct 16, 2015 12:26 AM
cmosentine
Aug 2, 2011 08:08 AM
stormcooker
Dec 1, 2009 10:28 PM
HDF Tech
Jun 25, 2005 11:55 AM
