Parts list needed for replacement of Flht Fuel filter? Would like to purchase all needed parts: gaskets, O-rings, check valve & hoses etc so job can be done without runs for additional parts.
Had a possible fuel issue in driving rain,,,,not good and should be solved before next trip.
There are a lot of parts inside the tank. But if you are planning on doing a filter change you only need two. The filter kit includes an o ring for the filter itself. Then there is a large o ring that goes under the top plate. Some people dont change that one every time but its a good idea.
Don't beleive so. Rained for over 2 hours, and problem lasted 30 minutes. 04 flht and I've never services the filter. I brought gas from a few stations the I normally would have passed by, but on back country roads in southern VA.
I went to my local dealer and the Fuel Filter Kit was $90. (Not a typo)
Gasket was under $10.00
They did not have all of the screws so I don't know the total cost of those.
Now, here are the after market part #'s from Drag Specialties:
0701-0733 Gasket (Around $21)
0707-0029 Fuel Filter (around $40)
If you google the part #'s you can make your own choices. I found the the filter cheaper after market and the gasket cheaper at a dealership. I am going to reuse the screws. You will also need a clamp tool.
I'm gonna hop in here and say thanks to those to provided the part #s. I will be need this shortly once I figure out whether I can save the assembly first. Anyone have any luck locating and aftermarket complete assembly or is that a dealer or used part only? Thank you
Harley made fuel injected touring bikes all the way back to 1995 the earlier bikes were M & M fuel injection.
Until about 2001 the bikes were M & M fuel injection and then it became Delphi fuel injection.
There would seem to be many model years between then and now.... not all model years are the same.
I did not see the year of your motorcycle.
If you wish to check year, bike model, part number and pricing then consider review of this parts link. http://partsfinder.onlinemicrofiche.....asp?make=hdmc
thanks for the help. Yes I forgot to mention the year make and model but this information answered all questions. Thanks again
