What is the difference between 02-07 rear wheel and 08? I know 08 has 25mm axle and cush drive (isolators) I think 08 was first year with isolators can I put the isolator pulley system on 02-07 wheel ? I'm not sure when they changed from 1" axle to 25mm axle
- The Cush drive was a "Bolt-on" in 08 only (can install on the earlier wheel)
- They started using 25mm bearings in 08 using the earlier wheel with a bearing shim under the "Primary Bearing" (08 only again)
