Stripped Shift Lever Shaft
Old May 28, 2018 | 06:54 PM
702's Avatar
702
Default Stripped Shift Lever Shaft
I recently picked up a low mile, one owner 2000 Electra Glide Classic.
The toe and heel shift levers were out of position for me, so I removed them to clock them different. Turns out the splines were fubar on the shaft and the shift levers.
A search here indicated this is common, with some grumbling about it, but no real solution.
For those who may not be aware, Harley has updated the shift levers. The updated version has a nut and bolt to pinch the lever to the shaft instead of the bolt threading into the opposite side of the bolt hole, which was pretty lame. The shift shaft also seems far more robust, and all is well again for me. A side benefit to this is that it is easier to find neutral now.
Happy Trails
Old May 28, 2018 | 09:00 PM
skydude426's Avatar
skydude426
This happened to me as well on my 2012 Ultra. I replaced the shaft and both levers. Since then, I use a goodly amount of blue locktight on the lever bolts and haven't had a problem again. Knock on wood.
Old May 28, 2018 | 09:16 PM
Iron25's Avatar
Iron25
i just check mine every 2500 miles or so
Old May 28, 2018 | 10:13 PM
HOGILAC's Avatar
HOGILAC
lock tite al most everything!
Joe from So Cal
Aug 6, 2021 01:39 PM
snooter
Sep 17, 2018 10:13 AM
T Man
May 11, 2018 08:07 PM
pontiac69
Aug 23, 2016 08:21 AM
Carpe Noctum
Dec 3, 2012 07:52 PM
