Brake Light
Old May 31, 2018 | 04:49 PM
ofame's Avatar
ofame
Stage IV
Default Brake Light
2003 Wide Glide No brake light. It's not the bulb. checked wires. Any idea of where the problem could be? Everything works except brake light(and gas gauge but I'm sure that's a separate issue.
Old May 31, 2018 | 06:46 PM
pdbuzz's Avatar
pdbuzz
I was hunting brake light problems this past weekend, parts dude at the local dealer told me to look at the board under the tail-light, where everything connects.
Old May 31, 2018 | 07:11 PM
ofame's Avatar
ofame
Stage IV
Solved! After I posted I kept messing around with it. I thought all along it was a loose brake wire. It turns out the base of the bulb doesn't sit properly in the socket. So it appears the connection is off. I wedged in a match stick and it works. Just a temp fix as I'll probably need a whole new assembly.
mike603
Jul 3, 2017 06:23 PM
supermanotorious
Apr 5, 2014 04:20 PM
NEXUSBULL
Feb 3, 2014 12:00 PM
sval
Aug 2, 2013 08:17 AM
Back Roads
Jul 8, 2012 07:45 PM
