Cruise control - 2016 Streetglide
I normally hold down the cruise, it goes orange, I set it , it goes green and holds at that speed. When Im behind someone or in a group, to keep the same speed as the guy ahead, I push up the button and it knocks up the speed 1 or 2 km/h to keep it even. It no longer engages when I tap the button up, it stays at the same speed. I can tap it down and it goes down (can feel it kicking in and slowing down)
hope this makes sense, anyone know what might be causing this?
Thanks!
OP, the Rushmore touring bikes have issues with the switch packs malfunctioning causing switches to stop working (seems to be more problems with the left side from seeing threads on the issue). With the newer Canbus system, the whole switch pack has to be changed out, they cant just cut and splice in a new switch. My kill switch stopped shutting the engine off after 1800 miles or so. At first it was intermittent, then stopped all together. The switch pack was replaced and theres been no issues since.
Typical canned response when someone is just looking for a little knowledge. Yeah they can take it in under warranty to be fixed, but that means they cant ask what is going wrong?
