Roadglide problems
Old Jun 9, 2018 | 09:59 AM
Vesa Kuivalainen's Avatar
Vesa Kuivalainen
Stage IV
Default Roadglide problems
i own -07 RoadGlides , now about two weeks ago it play tricks first time. Problems is that , i start engine and is round very well idlespeed and then i turn more run slowly (~4000rpm)it works, then i drop again idlespeed circle and turn fast engine speed -> engine stop right now.
New start, engine turn very well but now start. I wait about one hour, now it start and work good, now i tun fast engine speed-> stop.
thank you answer, i like drive somedays...
Vesa from Finland
PS: i check all errorcodes, no codes.
Old Jun 9, 2018 | 12:34 PM
ORradtech's Avatar
ORradtech
Sounds to me like a fuel delivery issue. Things like fuel filter fuel pump and fuel lines need to be checked.
Old Jun 9, 2018 | 01:17 PM
Mr. Mike's Avatar
Mr. Mike
Hello Vesa,
Could be fuel (pump*) related.
Fuel Pump Fuse (bad connections)
Fuel Filter
Tank venting
Hole in Fuel Line (in the tank)
*Replace System and Starter Relays (easiest to do yourself) and test.
Old Jun 9, 2018 | 01:57 PM
Guntoter's Avatar
Guntoter
In addition to the fuel filter, which probably is due for a change depending on mileage/kilometers or a hole in the internal tank fuel line, it could very well be the fuel line from the tank to the throttle body. If it shows wear like the photo below, on the fitting that goes into the tank, replace it as it is shutting off the fuel flow through the one way valve mounted at the tank.
Old Jun 9, 2018 | 02:54 PM
RevBlk's Avatar
RevBlk
Clean your IAC. 07's are well known for this fouling up. Remove your air breather and have a look in the throat of the fuel injection unit. Spray some MAP sensor cleaner in the little port while cycling the ignition on and off. I do mine twice a year.
Old Jun 9, 2018 | 03:08 PM
groupw's Avatar
groupw
Originally Posted by Vesa Kuivalainen
..... Vesa from Finland ......
..... some good info in the above posts, Vesa
......... glad to have you riding on the Sharkside
.... if you can get yer Road Glide runnin' right, you've still got time to make it to Sharkweek
.......... Durango's getting smoked out now, but come late July, it'll be good.
..... hope ya get the fueling issue cleared up quick ......
Old Jun 9, 2018 | 07:45 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
long thread in heear"07 idol issiues" iac,tps or tps adjustment,speed sensor. most common start with iac.
Old Jun 12, 2018 | 01:11 PM
Vesa Kuivalainen
Stage IV
Today i change fuel filter, fuel pump work normal and check all pipes but same problems is again... what is IAC?
Old Jun 12, 2018 | 02:01 PM
Cogswell's Avatar
Cogswell
Idle Air Control
Vesa Kuivalainen
Stage IV
Thumbs up
i turn this pipe... Bike work and then i turn more...engine stop?? Turn more back side engine running very well, maybe problems found , tomorrow i TaKe gas out and check this parts but what is this partsnumber. It maybe found ebay.
