remote wire
Old Jun 10, 2018 | 09:11 AM
kscote68's Avatar
kscote68
2nd Gear
Default remote wire
where is the amplifier remote turn on wire for a 2015 street glide special?
Old Jun 10, 2018 | 09:45 AM
nobodyknowsme's Avatar
nobodyknowsme
You need to elaborate. Aftermarket amp?
Old Jun 10, 2018 | 10:11 AM
kscote68's Avatar
kscote68
2nd Gear
Sinister Sound fairing skeaker and amp kit. Sound digital amp. That said that I would not have to get radio flashed with the additional"box" that plugs in to factory speaker harness and with rca cables to the amp. Their instructions state u may need to run a remote wire for "some" applications
Thank you!
Old Jun 10, 2018 | 10:28 AM
nobodyknowsme
IDK but my Hogtunes needs the gain set to -3. Can't help you with your wiring. Had mine installed as I don't hardly have time to ride so there may be an option on the infotainment, not sure. From what I understand the radio does NOT need to be flashed but not 100% on that either. There is an audio sub section that would better help you here on the forum.
Old Jun 10, 2018 | 10:36 AM
kscote68's Avatar
kscote68
2nd Gear
Thank you.
Old Jun 10, 2018 | 10:41 AM
ROCKOUT Rocker Products
Sponsor
You can tap into any wire that has +12v on it with the ignition switch in the run or acc position... most use the cig lighter wire. Just get one of those crimp on wire taps.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 10, 2018 | 10:55 AM
kscote68's Avatar
kscote68
2nd Gear
Thank you!!
Old Jun 10, 2018 | 11:27 AM
Budda109's Avatar
Budda109
I use the cig lighter as well. The trigger wire is very thin. Next to no voltage or draw. (12 volts) All it does is tell the amp circuit to wake up or go to sleep. Hope that helps
Old Jun 10, 2018 | 11:52 AM
kscote68's Avatar
kscote68
2nd Gear
Thank you! Just hooked it up to cigwire. Works now. Just need to adjust amp and reassemble!!
KSGLIDEGUY
Audio Systems
36
Mar 1, 2018 12:52 PM
toddrick
Audio Systems
Apr 29, 2015 08:42 AM
timber0472
Mar 1, 2015 09:46 AM
WB
Audio Systems
16
Jun 12, 2013 09:22 AM
Blt93932@aol.com
Jun 9, 2012 12:47 PM
