In addition to the wear bars or tread depth measurements already described, consider the tire’s age. Tires will deteriorate regardless of how far down your tread depth measured at - just a consideration.
If you have the HD Tire And Wheel Coverage, the tire must have a minimum of 3/32" or you are on your own.
For me and my bike, 3/32" is the mark to replace. On my other vehicles, it's about the same, unless I plan a trip or if it's winter soon, then I may do it sooner.
My Grand Daddy used to say "Drink good liquor and ride on good rubber and you'll be around a good long while, Son". In His day, a bad choice in either could be the end for you! (Recaps and moonshine).
For me it is when they get so squared off I feel like I am riding on a 2 X 4! Usually before the wear bars. I am also a 2 rear for every front guy. The last miles on that second rear can get a bit exciting!
In all seriousness, I keep a close eye on mine... Never let it go too far... If it gets low and I am going on a trip then it's a no brainer... I always have a spare ready to go on... I have been thinking of buying a tire changer...but I pay like $25 to get the local guy to change it.
Yes the metzeler on my Electra glide is quite square at the moment. & yes as u said I think my front is still fine. Have an Avon storm to get mounted but I wanna get the rear rim off myself. Haven't messed w a belt drive before. My rice burners were all shaft drive.
Either due to getting a flat or the tires just being noisy from wear, I seldom have gotten below 4/32's remaining. Usually if they are at 4/32's and I have a trip coming up they get replaced. If I get 11k out of the rear I am happy. I still replace the front every other time I do the rear. Unless something punctures the tire and throws me off schedule.
My Dunlops had 10/32nds on the rear and 6/32nds on the front when new. I am currently at 9900 miles on the rear with 5/32nds left. The front has 11,000 miles and is at 4/32nds. I should get another 6K out of the back and 11K out of the front. However, I've always changed at just under 15K on the back to be on the safe side. I don't get twice the miles out of the front so I change them at different times.
It's so true that tires can wear down quickly towards the end of their lives. My last tire looked like it might make it home on about a 2000 mile trip but when I checked it again after the first day I decided it wasn't worth taking the chance with 1400 miles to go while pulling a trailer.
The 2 rears before that had cord showing when I changed, one at the end of a trip, the other before I took off.
I agree with those who have said they get 10-12 K from rears and about double that on fronts.
It's a major expense on a bike, wish they lasted longer.
