Usually both down, as a matter of course, I ride a lot of chip sealed and older roads and the gravel strewn about makes 1 foot a little dicey at times. I will use left down only if Im on a hill and need to hold the rear brake while I roll on.
I used to put both feet down. After reading some good arguments on here, and learning form experience, I try to keep my right foot up, as much as possible. The main reason is is you have to stop unexpectedly, and the front wheel is turned, you want to use the rear,and not the front. If you don't have your foot in position, you have to use the front, and you're liable to drop the bike.
This is the second year, I've been working on keeping my right foot up. At first it felt awkward, and I only did it on level ground, when I had good balance. This year I can do it most of the time. If I suspect compromised traction, I still use 2 feet.
Normal stop ill start using both brakes until about 10mph or so. After that ill go to the rear brake for the last little bit so i dont risk locking up the front wheel. Once i stop ill let the left leg down, apply the hand brake, then put the right foot down.
I keep both feet up for as long as I can, and then almost always put both feet down. If all the weight of the bike is on one foot, that foot is more likely to slip; it's also easy to get caught out by gravel or a dip in the road so, if I'm only using one foot, there is a risk of overbalancing. I've lost count of the number of times advanced rider instructors have told me that the one thing they want to pick me up on is using both feet; I've given up trying to explain my reasons to them. UK road design means the risk of high speed rear ending is fairly low so, unless I feel at risk, I slip the bike into neutral just before I come to a complete halt. That's less strain on the clutch cable and mechanism, and less strain on my hand. I then put it into gear when the lights are about to change, or if I see in my mirror someone approaching too fast and I have an escape route. I personally knew someone who got rear ended while waiting in gear; the jolt meant he released the clutch and shot straight into oncoming traffic. Waiting in gear isn't always safer. If I'm on an unusually steep upward gradient I'll hold the bike on the brake pedal, but generally I find I can do a hill start by holding the bike on the front brake with my fingers while rolling the throttle cupped in my thumb and palm.
Two feet down at lights. I was a sportbike guy 10-15 years ago. Back then a rear brake was only used when added to the front for emergency braking, and to get the front tire back down when going to high in wheelies. Fast forward to cruisers and I still ride all front brake except slow speed turning and a panic stop, I hate using back brake on the Ultra, the factory pedal is in a crappy position. I engine brake all the time as well, so I barely touch the brake till I'm going slow at lights. Also depends on traffic behind me, I will tap brakes earlier to let people know.
Usually just left foot down, can vary with road grade or slipperiness. Right foot on brake, clutch pulled, in 1st gear. Have been known to put both feet down when necessary to avoid bike drop.
these were easy results to predict, just watch riders. HD riders predominately 2 feet and of those majority duck-walk. Sport riders 1 foot. Just my observations over 40 years. Bike size, one up,2-up, still 1 foot(actually on toes, but I could flat foot it easily).
Today, no feet.
I happened to be following a Illinois LEO the other day. When he came to a red light his left foot went down. I believe that LEO motorcycle cops are probably trained to do many things the same way. Maybe that's one of them.
I do both depending on what bike I'm riding, shovel usually one foot the taller & heavier RK both feet down unless I'm in the mood to play the balancing game then I try not to put a foot down.
Lol, Im the same. I usually come to a stop and put both feet down, then sometimes Ill put a foot back up if I know its a short light. I also sit there and practice my balance using throttle and rear brake if traffic is stopped but the light has changed, its fun to see how long I can keep it super slow rolling for without having to actually stop.
