Managing U-Turns and Sharp/Narrow Turns
Old Jun 22, 2018 | 12:00 PM
boydn1's Avatar
boydn1
All good advice, I' just moved up to a 17 Road Glide and it's WAY different then my Dyna. Also the friction zone on the new bike is VERY small...
Old Jun 28, 2018 | 11:13 PM
cficole's Avatar
cficole
lockandlean.com
Old Jun 29, 2018 | 12:41 AM
davewear's Avatar
davewear
Installing a lower rear brake pedal makes low speed friction zone stuff a lot more natural as well.
Old Jun 29, 2018 | 01:22 AM
IKnowNot's Avatar
IKnowNot
Originally Posted by Rob175
....PRACTICE, PRACTICE, PRACTICE! ...
LOOK where you want the cycle to go, and by that I mean TURN YOUR HEAD AND NECK ALL THE WAY AROUND and really LOOK ...
Work the "friction zone". ...
As others have said, buy the DVD "Ride Like A Pro" ...well worth the few bucks!
(emphasis added)
If you do not practice this regularly you will get complacent and not even realize it.
Old Jun 29, 2018 | 02:25 AM
Peter Griffin's Avatar
Peter Griffin
Sometimes I think the reason we don't practice is cause we might have to pick them up again.
Old Jul 1, 2018 | 12:30 PM
Sparkee...'s Avatar
Sparkee...
Just to add to the topic here, probably should start a new thread, but what about tips for turning around on a narrow road with an up/down hill grade?
I recently tried riding to the top of Mt Evans in Colorado although the weather was not very cooperative. I have no problems with slow speed maneuvers, the friction zone and dragging the rear brake. It started raining which turned to snow closer to the top which was no big deal until the snow/slush started accumulating on the road causing traction issues. Not much fun on a narrow rod with low visibly. I stopped on a reasonably good stretch with good visibility and no accumulation of slush to turn around however it was probably a 6 degree grade. Without thinking about the grade I got the clutch into the friction zone and a foot on the rear brake and almost laid the bike down when it got perpendicular to the road and it's grade. The "Ride Like a Pro" s turn with a dip would be a pretty risky maneuver at my skill level on a narrow road with a rock wall on one side and nothing on the other side.
FWI, it was still a great trip.
Sparkee...'s Avatar
Sparkee...
Duplicate Post
Old Jul 1, 2018 | 12:48 PM
vistavette's Avatar
vistavette
In theory it's the exact same process. And there is even a video online with Jerry from ride like a pro doing an uphill u turn. Like I said though, in theory. Although I've never been in quite as a precarious situation as a 6% grade in the type of weather you were in I've been in situations where it
was close and if my confidence level was up I probably could have made it, similar to your situation. In those instances I just did the best I could which meant in some cases I got off and just walked the bike around.
Old Jul 1, 2018 | 01:01 PM
e6fmf's Avatar
e6fmf
Practice, Practice, Practice, AT HOME. Not in the Black Hills during the rally, please....like so many others have done, and failed....
Old Jul 1, 2018 | 03:56 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Practice on clean good condition pavement in a big vacant parking lot. Note how many spaces it takes you to complete your move. Improve on that number SAFELY. Take your time, you will not get it all down the first day, but you will get better at it.
Mcfire12
Jun 19, 2014 07:13 AM
ghira75
Jun 16, 2012 01:29 AM
badinfluence63
Dec 11, 2008 04:16 AM
siramazing
Nov 21, 2006 04:37 PM
