electrical issues seem to be getting worse
Old Jun 24, 2018 | 02:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted
Old Jun 24, 2018 | 04:20 PM
brohoss's Avatar
brohoss
Back from auto zone. Battery tested at 94% charged. Not the problem. Hooked it up tried it a gain. Same results.
This time, heard a clicking sound coming from the starter, assumed it was the solenoid. Could that be why some things are not working?. Looks like I'll be replacing that real soon
Old Jun 24, 2018 | 07:27 PM
Dan89FLSTC's Avatar
Dan89FLSTC
That tells us nothing.
Was a load test done on the battery?
Old Jun 24, 2018 | 08:42 PM
brohoss's Avatar
brohoss
no load test, dont have the equipment
Old Jun 24, 2018 | 08:58 PM
Vernal's Avatar
Vernal
Does your battery drop below 10V when you hit the start button?
Put your battery on a charger and once it’s fully charged find a store or garage that can do a load test.
Old Jun 24, 2018 | 10:24 PM
brohoss's Avatar
brohoss
i will do that. thanks
Old Jun 25, 2018 | 10:04 AM
Z's Avatar
Z
1. Turn on your ignition.
2. watch the wall where your headlight is shining.
3. engage your starter motor.
A. If your engine doesn't turn over normally *and* your headlight doesn't dim, then the cause of your starter not doing it's thing is not primarily battery related. Look elsewhere.
B. If you headlight dims substantially and your starter doesn't crank your engine normally, then either your battery lacks sufficient cranking amps to start your engine, your starter is fried, or both.
This test costs no money and takes 30 seconds to perform.
I'm not trying to stear you awsy from your battery, I'm trying to get your diagnostics pointed in the right direction.
Old Jun 25, 2018 | 11:19 AM
00copglide's Avatar
00copglide
Default Check the main harness on the right side near the gooseneck
I had the same issues in my 2000 copglide...it turned out to be two broken main wires in the main harness that runs up the right side of the frame...just before it goes into the fairing ...I’ll bet it’s in there...when your having the no start issue ..reach in there and poke around at that area of the harness...maybe you’ll find something...Good luck!!!
Old Jun 26, 2018 | 08:13 PM
brohoss's Avatar
brohoss
thanks for the ideas everybody. Been working working a bunch of hours this week so far, i will
try those ideas real soon.Seams strange, it started with blinks, horn, radio, get gas light flickering, now nothing with the starter. will here real soon.
thanks again
hoss
Old Jun 30, 2018 | 11:05 PM
brohoss's Avatar
brohoss
Had the battery tested today. The shop charged it for 6 hrs. Load tested to 12.5 amps. So, bought new battery but, haven't
installed it yet, will do that tomorrow.
