Mystery
Old Jul 3, 2018 | 06:36 PM
Cruisineasy1's Avatar
Cruisineasy1
Default Mystery
This is pretty weird and was wondering if this has happened to anyone else..
I have a '14 SG. Last Thursday I gave the bike a once over. Aired up the tires. Only a lb. or two under. Rode to work on Friday. Short ride on Sunday. Front end washed out a bit in front of the house. Checked the tire pressure. Back normal, Front 0 PSI. WTF??? Checked the tire. no nails, screws, punctures or cuts. Aired up. No pressure drop of over 24 hours. Checked valve stem, no leaks.. Again WTF??? Only about 13,000 miles on the original HD tires.
Gonna pull the wheel and get a new tire this weekend. Kinda sucks 'cause there are several thousand miles left on the tread. Why would this happen???
Old Jul 3, 2018 | 06:42 PM
Kingglide549's Avatar
Kingglide549
Probably stuck valve.
Air it up and put a dab of spit on it and see if it slowly will blow a spit bubble.
Old Jul 3, 2018 | 07:04 PM
mmesa005's Avatar
mmesa005
Ditto.. I would suspect the valve. You can change the valve mechanism without chaging the entire valve.
Old Jul 3, 2018 | 07:17 PM
ORradtech's Avatar
ORradtech
Ditto.
It's called a Schrader valve. Should be available at any auto parts store.
Old Jul 3, 2018 | 07:20 PM
Kingglide549
Originally Posted by ORradtech
Ditto.
LOL
you SHOULD have a couple in the big roll around!
Old Jul 3, 2018 | 07:22 PM
ORradtech's Avatar
ORradtech
Originally Posted by Kingglide549
LOL
I do, Don't know about the OP though...
Old Jul 3, 2018 | 07:24 PM
Kingglide549
I should have said "WE'
Old Jul 3, 2018 | 07:47 PM
nobodyknowsme's Avatar
nobodyknowsme
Old Jul 4, 2018 | 04:21 AM
grbrown's Avatar
grbrown
Could be as simple as a loose valve, so check it is tight in the valve stem. As for 90 degree bends, I had a failure using one of them on a rubber valve stem - it split the stem and left me by the roadside. If you have metal stems they should be fine.
Old Jul 4, 2018 | 09:33 AM
Cruisineasy1
Thought it might be the valve. Gonna swap it out. Sucks 'cause I ride to work on a pretty isolated road with no cell service. Would really suck to get stranded..
Thanks for the help..
HAPPY 4th. everyone!!!
